Go Back   AVForums.com > Home Cinema Construction and Configuration > Home Cinema DIY
Latest AVForums Movie Reviews
Galaxy Quest Blu-ray ReviewMy Bloody Valentine - Special Edition Blu-ray ReviewThe Universe: Complete Season One Blu-ray ReviewTerminator Salvation Blu-ray Review20th Century Boys: Chapter 2 - The Last Hope Blu-ray Review
North By Northwest (50th Anniversary Edition Blu-ray Book) Blu-ray ReviewScrooge (A Christmas Carol) Blu-ray ReviewGray Lady Down - Original Motion Picture Soundtrack CD ReviewUp Blu-ray ReviewLéon Blu-ray Review
My Home Cinema/Lounge fuel2000 Members' Home Cinema Gallery 51 25-03-2009 10:36 PM
PS2 GTA San Andreas on PS3 80GB UK PAL? Mark4190 PS3 11 10-01-2009 2:15 PM
"PS3 is dying on the Shelves" I think NOT!! WildgooseUK PS3 396 06-01-2009 11:37 PM
Poor connection when hosting games on COD4 r.vernon1 Call Of Duty (COD) Xbox 360 12 02-01-2009 3:39 PM
Old 02-01-2009, 3:46 PM   #1 (permalink)
dazzler9000's Avatar
Thanks: Gave 45, Got 22
Building a box to sit my floor standing speakers on????
Hello chaps,
I've had my Monitor Audio GS20's speakers for a year or two now. Due to the shape of my room one of them sit behind the arm of a chair. This has always annoyed me as I'm sure it's not helping with the acoustics. The speaker has three speakers and it's the bottom bass cone that is being blocked by the chair.
Moving the chair isn't an option so I'm considering building a box to sit them on. The only problem is that the boxes would need to be about 30cm's high. I'm not sure how I'd get a solid base and would I do more damage than good due to poor speaker isolation (not sure I believe in it!!)
Any ideas would be great.
I'll also add a photo tonight.
Lounge:Pioneer PDP-LX5090|Yamaha RX-V3900|Marantz DV7600|ATC SCM40|MA GS20's|MA GSLCR|BK Monolith|Squeezebox 3|2x Logitech 895|Wii|HTPC
Bedroom:Pan TH50PZ80|Yamaha RX-V2600|5x M&K Xenon LCR26|M&K-V850|SB 3|HTPC
Garage:Pan PTAX100|92" screen|Sony dav-s800|Xbox360|PS3|HTPC
dazzler9000 is offline   Reply With Quote
Old 02-01-2009, 6:29 PM   #2 (permalink)
Thanks: Gave 13, Got 35
Re: Building a box to sit my floor standing speakers on????
I would just build a box out of MDF and paint outside to suit. Make sure the bottom of the box is sealed with the aid of some silicon bathroom sealant. Then fill the box with kiln dry sand. Then securely fit the lid of box. The box will now be solid, heavy and non-resonant.
I think Quantas did something similar for the stage area in his cinema room build.
Here - posts 35 -43.
GlynG60 is offline   Reply With Quote
Old 02-01-2009, 7:13 PM   #3 (permalink)
Thanks, I don't think I'd get away with using MDF as we've recently laid Oak flooring and I think the other half would have something to say about it. I like the sand idea though. I was considering some speaker stands but I think I'd be lucky to find some that would fit in the space I have.
Thank for the link, i'll check it out.
Here are some pics of the setup anyway.
Old 02-01-2009, 8:10 PM   #4 (permalink)
Thanks: Gave 29, Got 136
If you feel the need to raise the speaker, I strongly suggest you do them both. It'll sound very strange if they are at different heights. Might give you the opportunity to move the one on the right further away from the corner, which would improve things too.
deckingman is offline   Reply With Quote
Old 02-01-2009, 9:06 PM   #5 (permalink)
Hi Deckingman,
Yes I'll definitely be doing both speakers.
I'll hopefully be getting a new TV later on in the year so I should be able to get a smaller rack which should enable me to bring the right one out of the corner a little bit.
Unfortunately I have fairly large kit so placement is difficult and there isn't much room for maneuver.
box, building, floor, sit, speakers, standing
