3.5 million visitors each month
Go Back   AVForums.com > Home Cinema Construction and Configuration > Home Cinema DIY
Latest AVForums Movie Reviews
Star Wars: The Clone Wars Blu-ray ReviewPublic Enemies - Original Motion Picture Soundtrack CD ReviewAudition Blu-ray ReviewPolice Story Blu-ray ReviewYear One Blu-ray Review
The Living Dead At Manchester Morgue Blu-ray ReviewPublic Enemies Blu-ray ReviewGojira Blu-ray ReviewHalloween II Original Motion Picture Score - Expanded 30th Anniversary Edition CD ReviewStar Trek - Complete Original TV Show Season 2 Blu-ray Review
House extension/renovation in London. To AV or not to AV - that is the question! Andyjc Home Cinema DIY 67 29-10-2009 12:49 AM
just bought phillips dvp5990/05 - usb question bertybath DVD Players 5 06-01-2009 5:39 PM
DAVIS50 HDMI Question balster All-in-one Systems 15 02-01-2009 11:55 PM
First Post..........Stupid Question Pl3st3r Xbox 360 Games 3 29-12-2008 12:18 PM
Output question on AVR-1909 Nikumba Denon Owners' Forum 1 27-12-2008 10:51 PM
Old 28-12-2008, 2:39 AM   #1 (permalink)
Question regarding instilation..
hey guys... this will be my first time setting up a home theater system and i have a few questions. your help would be greatly apprecited.
my house is currentlyt under renovation and i would like to install wires now while i can hide them behind walls etc... i just purchased an LCD tv which i would like to mount on my wall. i have a yamaha receiver with 4 HDMI in and 1 out. i would like to run a sony blu ray player, HIdef Cable box, and xbox 360 through the system.
i am wondering if all i have to do is run an HDMI for each component to the reciever and then just ONE HDMI to the LCD on the wall?? will that cover sound and video?? i have speaker wires already installed in the wall and a power outlet behind where the TV will be mounted. i just want to be sure of what i need before i complete renovations.
Thanks for you help
bbdd005 is offline   Reply With Quote
Old 28-12-2008, 2:46 AM   #2 (permalink)
Thanks: Gave 3, Got 8
Re: Question regarding instilation..
Yea that will work fine mate.
Jay-Ree is offline   Reply With Quote
Old 28-12-2008, 2:51 AM   #3 (permalink)
easyrider's Avatar
Thanks: Gave 13, Got 26
If you want to run the TV's audio output to your AV amp then make sure you have the correct leads going from your TV in the wall.
My TV has stereo Composite out so I am running One HDMI cable from TV to AMP to take care of video and a stereo Composite lead to carry the audio from the TV into the amp.
You want the option to allow your TV's audio signal to go in the AV amp.
My Home cinema build Onkyo 876/PS3/Tannoy F4/F1/FC/Optoma HD700X/92" Screen/Sky HD
easyrider is offline   Reply With Quote
Old 28-12-2008, 9:14 AM   #4 (permalink)
Thanks: Gave 21, Got 90
I would say run 2x HDMIs and also put in 2x Coax (e.g. FT100) and 2x Cat5e
AV:Samsung 19" (Kitchen) 32" (Bedroom) 40" (Lounge), Panasonic PT-AX200, SkyHD, Pioneer 868, Onkyo 605, MS902i/905/302, BK XLS200, Harmony 885 x2, Squeezebox Duet, HTPC Gaming:360 Elite PS3 Wii Modded Xbox Flashed PSP
My old bedroom setup My new home cinema and multiroom - DIY work in progress
MitsiTurbo is offline   Reply With Quote
Old 28-12-2008, 9:31 PM   #5 (permalink)
thanx for the help guys, what would i need the above cabels for?
Old 28-12-2008, 9:59 PM   #6 (permalink)
Question Re: Question regarding instilation..
Not an answer but a REQUEST FOR ADVICE FOR MYSELF.
I have two (20) toshiba DVD recorders (30gb & 160GB) that I want to cross-link for dubbing btween them and both to link to my 32" HD Samsung LCD TV.
Samsung has HDMI but the tosh's do not.
I have a paper somewhere (which I cannot find) which lists the standards in terms of quality and transfer rate.
From memory this had composite lowest followed by S-video with SCART highest quality.
Component was higher than SCART and HDMI was top of course.
I am happy to use co-ax if it will give me good quality video & sound becauase I had video TV wired to every room using very hig quality co-ax and satellite distribution system some 14 years ago. However I suspect that SCART or component connections for the back to back links will be better than co-ax.
Can one of you guru's give me some idea which connections will be me best qulity.
Thanks.
skeeve is offline   Reply With Quote
instilation, question
