Originally Posted by da_murphster
Having spoken to an electrician he said he often uses ventalation trunking.
Got some from Screwfix but concerned that it is too big! (110x55)
Really? Sounds perfect
Get a couple of 47 mm back boxes, one for each end of the trunking and two double gang brush plates to finish it nicely.
Especially as I was going to do separate ones for scart etc and power.
You could always get something smaller for the power leads... It only needs to be big enough for the plug that goes into the TV etc.
Now I am concerned that if I sink it in the plaster may not stick to it of that the trunking will flex and the plaster will crack.
Sink the trunking in so it is about 10mm below the surface of the wall. Then before the finish coat use a coat of bonding plaster (sticks to anything include non-porous surfaces). Scrim tape shouldn't be necessary but certainly won't hurt.
Secure the trunking in the channel you cut using screws and plugs. The trunking should be rigid enough that when secured it won't flex at all. Certainly what I used in my living room was fine. I have more than enough space for any cables I could possibly ever need and the finish is great.
If you're feeling nervous about it then perhaps you shouldn't do it. If you have faith in your DIY skills and the tools/patience to do it then you will be pleased with the results. If you do take the plunge, just take your time planning it and you'll be fine.
