| Re: 120" fixed frame projection screen help
I simply used cut MDF pieces with 48 inch long and 8 inches deep (18mm thick) mounted the first panel to the wall with adhesive and platerboard fixings (to pull the piece tight and flush and assist the adhesive)
I then mounted two additional pieces on top to bring the mounting out to a total of over 50mm to clear a dado rail as my screen is wall mounted and I needed to lower it a little and the wall dado rail was in the way. These were mounted with adhesive and screw fixings.
These plates are then used to mount the fixed screen supports
The reason I used 8" deep was to ensure a good wall fixing and allow flexibility with vertical screen placement
__________________ Film JVC HD100,Carada BW variable masking,Denon 3800,Dacmagic, Oppo 983,Arcam AV8, P1, P7,Naim 135x4,Naim 250x2, Usher R1.5,Sonus Faber Extrema, Cremona, Elector amators, Gravis, 8033, Naim NACA5, Chord. Music Linn Sondek,Syrinx,Koetsu Red, Denon DCD3300, Croft, Tron 211, Living voice Airscout Horns
