AVForums - Free Audio Visual electronics advice and information
AVForums.com twitter page AVForums.com facebook page AVForums is a member of CEDIA. THX certified reviewer.  Click for more information. AVForums reviewers are ISF Certified.  Click for more information.
Forum List Register Blogs Information Social Groups Search Today's Posts Mark Forums Read
Go Back   AVForums.com > Forums > Home Entertainment Players and Recorders > All-in-one Systems
Latest popular product pricesPowered by
Sony BDV-E370
Samsung HT-C453
Logic3 Soundstage 5.1
Samsung HT-C5500
Sony BDV-E370
Samsung HT-C453
Samsung HT-C5500
Sony HT-IS100
LG HT805TH
Sony DAV-DZ330
Panasonic SC-PT480
Sony BDV-E870
Samsung HT-C555
 More...Prices updated July 30th at 1:30pm and include delivery.
LinkBack Thread Tools
Old 11-12-2008, 10:30 PM   #1
Home Cinema System Set-Up/Recommendation
I have an HD Samsung Tv.
A Sony PS3
A laptop with dvi output.
And an ipod.
I'm looking for a home cinema system for christmas and i have no idea if i can hook up all of these with one. Im assuming i can hook up the ps3/laptop by using HDMI cables.... but then how does the TV recognise them? Also how does the system connect to the TV?
In addition to these questions can anyone recommend a system which does all the above for £250 or below?
doofeh is offline
Digg this Post!Add Post to del.icio.usBookmark Post in TechnoratiFurl this Post!Share on FacebookShare on Twitter
Old 12-12-2008, 5:04 PM   #2
Re: Home Cinema System Set-Up/Recommendation
come on people its an easy enough question for anyone with basic knowledge of how these things work?
doofeh is offline
Old 12-12-2008, 7:14 PM   #3
Grangey.'s Avatar
Thanks: Gave 69, Got 94
I actually have no idea what your asking. You want to connect your ps3 and laptop via hdmi, and you dont know how your tv will recognise them?! huh?!
And how does the system connect?? As you would expect. PS3-tv via hdmi. Laptop- TV via DVi-HDMI lead. Ipod-Laptop.
And with that in mind, what system are you looking for to spend £250 as all that will work on its own????
Sony KDL40W2000, Onkyo TXSR875B, SONY PS3, Xbox 360, Sky HD, Wii, B&W 603's, AE 107C, and some cheaper speakers to compleate the 7.1 Speaker setup.
Grangey. is offline
Old 12-12-2008, 7:23 PM   #4
inzaman's Avatar
Thanks: Gave 105, Got 427
It would be even easier had you posted this in the correct section, so moved to all in ones for you
Visit my Home Cinema here
inzaman is online now
Old 13-12-2008, 1:17 PM   #5
Sorry i realise it has all been worded wrong.
If i connect my ps3 and laptop to my tv then connect a home cinema sytem to my tv, will all of these work with surround sound? Also are there any systems which allow me to connect my ipod not via my laptop. And what one would you recommend for under £250?
doofeh is offline
Old 13-12-2008, 2:13 PM   #6
Thanks: Gave 31, Got 25
Your TV in that situation from my understanding would only be outputting stero sound not 5.1
You will need to connect the PS3 and your laptop directly to the amp to get surround sound though the thing is i'm not sure what outputs your laptop has.
My suggestion is to have a look at the Sony HT DDWG800 thread in this section as I think it will do exactly what you need and it is also within budget. What you can do is connect your PS3 via HDMI to the AMP then a HDMI cable to your TV. If you want your iPod playing through your amp then I suggest investing in a 3.5" to 2 phono cable and using one of the audio inputs in the back on the amp.
LeoWyatt is offline
cinema, home, setup or recommendation, system
[IMG] code is Off
Optimised for Firefox
AVForums.com is owned and operated by M2N Limited
Copyright © 2000-2010 M2N E. & O. E.
