Go Back   AVForums.com > Home Cinema Construction and Configuration > Home Cinema DIY
Latest AVForums Movie Reviews
Up Blu-ray ReviewLéon Blu-ray ReviewNear Dark Blu-ray ReviewLogan's Run Blu-ray ReviewTaking of Pelham 1 2 3, The Blu-ray Review
Star Trek Blu-ray ReviewUFC 100: Lesnar vs. Mir (2009) Blu-ray ReviewThe New York Ripper Blu-ray ReviewHeat Blu-ray ReviewMoon Blu-ray Review
Help with locating RS SPL ralphmalph Subwoofers and Tactile Transducers 2 03-06-2008 7:28 PM
Need help in locating film atacam Movies and The Cinema 9 26-07-2005 5:39 PM
Help in locating a TV theme! PoochJD On Television 6 06-11-2004 1:11 AM
Locating a Sky signal S2KI Sky and Sky+ 1 18-05-2003 6:48 PM
Locating CDs by track title auldendunn Music 8 03-04-2003 8:15 PM
Old 19-11-2008, 10:17 PM   #1 (permalink)
Thanks: Gave 8, Got 3
Locating DVD player etc. far from the TV
In the new year I plan to start work on moving the TV onto a wall bracket and chasing the speaker cables into the walls etc. However, rather than doing the "normal" thing of locating the freeview box, DVD player and receiver AMP in a unit close to the TV, I'd like to locate it on the other side of the room, near the sofa, some 4m from the TV.
I have a mixture of device connections; Scart, Component, DVI, RGB and HDMI. All of these would need to be located away from the TV.
What is the best way to do this? The HDMI and DVI cables can simply be run as they are but what about the others?
Can I get a "hub" to connect them all into then send them to the other side of the room on Cat5e before splitting up the signals again to enter the TV?
Will I suffer from lip sync issues if the images has to go 5m further than the audio ?
Goochie is offline   Reply With Quote
Old 19-11-2008, 10:45 PM   #2 (permalink)
Oily's Avatar
Thanks: Gave 47, Got 47
Re: Locating DVD player etc. far from the TV
Try here for cables etc:
AV Cables and Interconnects, UK Cables Shop
My DIY AV rack http://www.avforums.com/forums/av-st...e-av-rack.html
My floating wall project:http://www.avforums.com/forums/home-...ks-groove.html Work is for people who don't know how to fish!!
Oily is offline   Reply With Quote
Old 19-11-2008, 10:52 PM   #3 (permalink)
Assured Advertiser
hornydragon's Avatar
Thanks: Gave 95, Got 1,331
5-10m cables runs aren't an issue. To convert to Cat5 would cost alot more.
Life's better when it's wired! - Wired Life
Proud to be an AVForums sponsor and assured advertiser
hornydragon is offline   Reply With Quote
dvd, locating, player
