Go Back   AVForums.com > Home Cinema Construction and Configuration > Home Cinema DIY
Latest AVForums Movie Reviews
Up Blu-ray ReviewLéon Blu-ray ReviewNear Dark Blu-ray ReviewLogan's Run Blu-ray ReviewTaking of Pelham 1 2 3, The Blu-ray Review
Star Trek Blu-ray ReviewUFC 100: Lesnar vs. Mir (2009) Blu-ray ReviewThe New York Ripper Blu-ray ReviewHeat Blu-ray ReviewMoon Blu-ray Review
HELP floating roof ! ProjectorDreams Home Cinema DIY 4 22-10-2008 3:48 PM
i need a black glass 6 shelve av stand!!! steel_kelly AV Stands, Cabinets, Seating and Furniture 1 04-06-2007 7:30 AM
Old 18-11-2008, 5:46 PM   #1 (permalink)
Thanks: Gave 113, Got 100
Large Floating Shelve Brackets
Hi All,
I am attempting to make a large floating shelf that will be placed at the corner of two walls for extra support but I am in need of appropriate concealed brackets/supports I can fix on both walls for adequate strength for the size of shelf. Does anyone know of something that I can use - I have found some pics of something that may be ideal but cannot source them anywhere! Also below is a pic of what I am trying to achieve! Any help would be greatly appreciated as all my efforts have proved fruitless so far!
Thank You!
Suave!
Suave is offline   Reply With Quote
Old 18-11-2008, 9:20 PM   #2 (permalink)
thefathacker's Avatar
Thanks: Gave 16, Got 3
Re: Large Floating Shelve Brackets
Suave - haven't seen anything that size - I know Homebase do the bog standard ones - I've got some in my office. They are nowhere near strong enough though - they bend with a few lever arch files on!
Have you considered using studding or round bar? You could get the appropriate size (say 15mm?) and resin anchor them into the wall - that would certainly be strong enough.
Screwfix sell the studs and the resin - though having seen what they're charging for the studding - you could probably save money by improvising via a local scrap yard.
thefathacker is offline   Reply With Quote
brackets, floating, large, shelve
