I looking to attach a 50" plasma TV to a dab wall and looking for some advice.
The wall is 12mm of plasterboard, with dabs of adhesive roughly the size of your fist, 12mm void and then masonry.
Having read through Groove's install of his floating wall set up he uses heavyweight anchor bolts bought from B&Q.
Thread link -
Groove's new lounge with floating wall build
However, Groove's wall is solid with no plasterboard. Are these bolts likely to do the job for me if I drill through into the masonry beyond the void and anchor them there?
