Go Back   AVForums.com > Home Cinema Construction and Configuration > Home Cinema DIY
Latest AVForums Movie Reviews
Gray Lady Down - Original Motion Picture Soundtrack CD ReviewUp Blu-ray ReviewLéon Blu-ray ReviewNear Dark Blu-ray ReviewLogan's Run Blu-ray Review
Taking of Pelham 1 2 3, The Blu-ray ReviewStar Trek Blu-ray ReviewUFC 100: Lesnar vs. Mir (2009) Blu-ray ReviewThe New York Ripper Blu-ray ReviewHeat Blu-ray Review
Advice needed on my 1st build... m_r_c Home Cinema PCs 2 25-09-2008 6:36 PM
HTPC/LCD project Advice....really needed! le geordie Home Cinema PCs 5 13-05-2008 8:20 AM
New build project - ADVICE PLEASE! Johnsuede Custom Installations and Installers 30 08-01-2008 6:56 PM
First PC Build Help and advice needed pants23 Computer Systems 12 23-06-2007 4:43 PM
New PC build - advice needed on this spec.. Bigmonty69 Computer Systems 2 06-03-2007 5:58 PM
Old 18-11-2008, 12:32 AM   #1 (permalink)
advice needed on new build project
I have just joined as i am looking for advice, all opinions apreciated.
I am currently in the process of a self build house project, In which i plan to have two plasma tv's
1. In a downstairs open plan kitchen/dining /family type room in that order. i have had speaker cable wired in to the relavent corners for 5.1 set up. ( wife would not ware the addition of the two middle for 7.1) also four cat 6 cables and an HDMI, this room is large and is getting a tv in the 60" range. I am looking at the Q acoustic 1010i spaekers. I need an upscaling amp which along with all other components wi live in a cupboard upstairs i plan to use a multi remote and IR pick ups and transmitters to make it al work. so amp need to have several inputs for blue ray / skyHD/ bt vision and possibly music films streamed from a PC.
2.Upstairs lounge will have one plasma Around 40" and no surround. I plan a decent separate stereo set up for this room later as funds allow, there is also Cat 6 to the tv and future stereo loction
I do not mind spending more than s proportianal to the speakers on an amp as they may get upgraded in the future. But as you can imagine i have a lot to do at once not to mention the Joy of a bare shell house to carpet and furnish so the budget is notlimitless
Questions
1. can i get one amp that would be capable of running the two tvs and handeling different output input at the same time.ie. sky to one while playing a dvd on the other or do i need to buy one amp and one other box to upscale for the smaler tv 2.
2.any particualr TV you would recomend for #2 as it wil need to have a good sound output on its own. and possibly good upscaling
I did initialy look at building a high spec media PC to handle all these tasks. but i work away for extended periods and if it went down while i was away it would ean them indoors entertainment frre until i got back and a bent ear for me
rotaxds is offline   Reply With Quote
Old 18-11-2008, 9:44 AM   #2 (permalink)
inzaman's Avatar
Thanks: Gave 91, Got 365
Re: advice needed on new build project
Hi welcome to the forums, with regards to the 2 questions you are best asking them in the specific parts of the froums. The receiver or amp question in the receivers section and the TV question in the relevant TV section e.g. Plasma or LCD
Visit my Home Cinema here
inzaman is offline   Reply With Quote
advice, build, needed, project
