Go Back   AVForums.com > Home Cinema Construction and Configuration > Home Cinema DIY
Latest AVForums Movie Reviews
Gray Lady Down - Original Motion Picture Soundtrack CD ReviewUp Blu-ray ReviewLéon Blu-ray ReviewNear Dark Blu-ray ReviewLogan's Run Blu-ray Review
Taking of Pelham 1 2 3, The Blu-ray ReviewStar Trek Blu-ray ReviewUFC 100: Lesnar vs. Mir (2009) Blu-ray ReviewThe New York Ripper Blu-ray ReviewHeat Blu-ray Review
BK XLS300- How excited should I be? bigsav Subwoofers and Tactile Transducers 4 24-05-2008 10:46 AM
Got my xls300! Flash3d Subwoofers and Tactile Transducers 6 24-02-2008 12:58 AM
BK Electronics BK XLS300/PR Russell.Williams Subwoofers and Tactile Transducers 88 10-12-2007 11:15 AM
bk xls300 handman Subwoofers and Tactile Transducers 9 20-11-2007 1:19 PM
BK XLS300/PR set up Jalapeno Subwoofers and Tactile Transducers 13 24-10-2007 6:29 PM
Old 17-11-2008, 11:14 PM   #1 (permalink)
Thanks: Gave 0, Got 29
My bk xls300 attempt
thought i would build myself a couple of bk xls300pr as i have a couple of peerless xls 10s kicking around, all i will have to buy is a couple of bk plate amps and 2 passive radiators and some 25mm mdf. i needed the subs to be smallish thats why i chose the 300 to copy, i already have there xls200 wich is good for a small sub, i am hoping to achieve a little better result with 2 xls 300's, just wondering if anyone has 2 of these runing together and if so what do they sound like. I will up some photos later.
just added a couple of photos of the cabs primed ready for top coat, should be ready for about mid week will post a couple of pics of finished items.
one of the cabs is now finished and has turned out very well and sounds pretty good even if i do say so myself, it will be nice to get the other one done so i can compare the difference between 1 and 2 subs running.
what dya think,
My bk xls300 attempt-img_0744.jpg   My bk xls300 attempt-img_0747.jpg   My bk xls300 attempt-img_0757.jpg   My bk xls300 attempt-img_0759.jpg   My bk xls300 attempt-img_0756.jpg
My bk xls300 attempt-img_0765.jpg   My bk xls300 attempt-img_0767.jpg   My bk xls300 attempt-img_0782.jpg   My bk xls300 attempt-img_0789.jpg   My bk xls300 attempt-img_0790.jpg
leedude03 is offline   Reply With Quote
Old 28-11-2008, 11:44 PM   #2 (permalink)
Re: My bk xls300 attempt
I must admit that of all the tasks on this project, the painting of the cabs was by far the most traumatic, but well worth the effort.
Old 29-11-2008, 9:48 AM   #3 (permalink)
Thanks: Gave 22, Got 91
Looks great! Kinda missing the grille though. I would love to have the space to do that. How do you go about rounding the edges and corners off?
AV:Samsung 19" (Kitchen) 32" (Bedroom) 40" (Lounge), Panasonic PT-AX200, SkyHD, Pioneer 868, Onkyo 605, MS902i/905/302, BK XLS200, Harmony 885 x2, Squeezebox Duet, HTPC Gaming:360 Elite PS3 Wii Modded Xbox Flashed PSP
My old bedroom setup My new home cinema and multiroom - DIY work in progress
MitsiTurbo is offline   Reply With Quote
Old 29-11-2008, 11:00 AM   #4 (permalink)
used a router with a corner bit they come with a different sized radius, i know where you are coming from about the grill, this will be my next task but not decided how to go about this yet.
Old 29-11-2008, 5:25 PM   #5 (permalink)
Thanks: Gave 170, Got 68
Nice work there! I have a gloss black xls300 and it looks nigh on identical - even the 'monolith' feet.
Your plate amp looks to be a different model though. Mine has the gain/phase etc. controls mounted vertically on the left.
BikeNutt is offline   Reply With Quote
Old 29-11-2008, 6:36 PM   #6 (permalink)
Thanks: Gave 603, Got 515
Hi Lee
they look really pro mate, I wish I could do summat like that but you really need all the joinery tools for such a project.
As to the grill, I looked on ebay a while back and found a bloke who made them out of perforated steel, you know little holes all over it. He folded the edges as well so no nasty edges and if you wanted powder coated them, about £15 each mate so not that expensive and they look fantastic.
Anyway great job, can you build me a pair of SVS jobbies, you know summat nice and massive
cheers Al
See my selfbuild/basement cinema...Part 1 Big Al`s Big Basement Build Bonaza... Part 2
JVC HD350-Onkyo 905 MK SW150s MK SW95s MK SW85s MK MX5100 SF MONSTER 118" fixed screen-Harmony 1000-HTPC 8TB
albriscoe is offline   Reply With Quote
Old 30-11-2008, 12:38 AM   #7 (permalink)
Bike nut you are correct about the amp, it is actually a xls 200 amp modified by bk themselves and apparently it is the same amp as the xls 300 when the mods are done apart from its physical looks. The feet i machined out of ally,
Albriscoe thanks for the tip for the grill will have a look and see.
and thanks for the kind words.
Old 30-11-2008, 1:38 AM   #8 (permalink)
IronGiant's Avatar
Thanks: Gave 581, Got 1,553
Nice work
from an old DIYer
Dave
We all stand on the shoulders of giants...
My personal opinion is not necessarily AVF policy.
IronGiant is offline   Reply With Quote
Old 30-11-2008, 8:11 AM   #9 (permalink)
Thanks: Gave 23, Got 41
looks great mate,
you paint it yourself?
deansocial is offline   Reply With Quote
Old 30-11-2008, 10:42 AM   #10 (permalink)
I did all the work myself apart from making the amp mods, BK did this when i purchased them. All that is remaining for me to do is sort a grill out, i would like to make the grill a little unusual so am still working on that.
Old 04-12-2008, 4:27 PM   #11 (permalink)
I have now done the grills on this what dya think, was going to do them red but left them black,
My bk xls300 attempt-img_0793.jpg   My bk xls300 attempt-img_0794.jpg   My bk xls300 attempt-img_0795.jpg   My bk xls300 attempt-img_0796.jpg
Old 04-12-2008, 7:46 PM   #12 (permalink)
Thanks: Gave 11, Got 12
love the paint job. what paint did you use?
king blaze is offline   Reply With Quote
Old 04-12-2008, 9:04 PM   #13 (permalink)
i started off with 5 coats of pva watered down 3 to 1 light dry flat with 600s in between coats, then 2 coats of high build primer flated in between coats with 600s but this time wet, then 3 good coats of celulose wet flat with 1000s then another 3 coats flated with 1500s and finished with fine compound and t cut then wax.
forgot to add these photos can anybody guess what its for
My bk xls300 attempt-img_0797.jpg   My bk xls300 attempt-img_0798.jpg   My bk xls300 attempt-img_0799.jpg
Old 05-12-2008, 11:07 AM   #14 (permalink)
danmc_82's Avatar
Thanks: Gave 338, Got 178
Not a magnet is it for the rear of a speaker?
Excellent Job you have made on the sub by the way.
Kit List: SkyHD, PS3 160GB, Yamaha RX-V1900, Monitor Audio RS6, RSLCR, RSFX, XLS 300PR, Sony 40KDLW2000 LCD.
PSN: danmc_82
danmc_82 is offline   Reply With Quote
Old 05-12-2008, 2:10 PM   #15 (permalink)
Thanks: Gave 5, Got 7
Im assuming that you are using them to add additional mass to the PR's.
AV ---> Onkyo 674E Receiver, Tannoy F4 Custom, DIY Sub in the works.
HiFi ---> Sony ES amp, Marantz CD6000 OSE LE Modified and AElite 2 speakers.
gregmcquaid is offline   Reply With Quote
attempt, xls300
