| Re: Plasterboard LCD Mount
18mm MDF will easily support a TV weighing 23kg. No need to worry, just wood screws straight into it, but be careful not to overtighten them as it is relatively easy to strip out the holes. Do bore pilot holes before screwing in the screws.
At my previous workplace I built a floating wall using 11mm MDF with 2" x 1" strapping as the framework behind it. We had a Pioneer PDP428 mounted on it (previously a 427, and before that a 40" Samsung). If I remember correctly the Pioneer weighed around 30kg.
As far as the construction is concerned you could simply screw wooden battens horizontally at 3 or four heights (bottom, top, and two evenly spaced in the middle) directly to the wall. This would allow you to screw into the supporting studs behind the plasterboard for better support. Then you could screw straight onto these battens.
You could make these battens vertical instead which would more easlily allow cables to be run behind the MDF.
