Go Back   AVForums.com > Home Cinema Construction and Configuration > Home Cinema DIY
Latest AVForums Movie Reviews
Terminator Salvation Blu-ray ReviewGray Lady Down - Original Motion Picture Soundtrack CD ReviewUp Blu-ray ReviewLéon Blu-ray ReviewNear Dark Blu-ray Review
Logan's Run Blu-ray ReviewTaking of Pelham 1 2 3, The Blu-ray ReviewStar Trek Blu-ray ReviewUFC 100: Lesnar vs. Mir (2009) Blu-ray ReviewThe New York Ripper Blu-ray Review
Problems getting TV sound through LG home Cinema - 37LC46 TV and HT552TH home cinema zap48uk Interconnects, Speaker Cables and Switches 18 05-07-2009 11:26 PM
Advice on all-in-one home cinema option needed by Home Cinema Newbie tunaboy777 All-in-one Systems 2 24-01-2008 9:50 PM
Panasonic 5.1 Dolby Digital Home Cinema DVD Player vs Sony 5.1 Home Cinema System shuRe Speakers 0 04-07-2007 7:58 PM
Reviews of Hitachi 42PD5X00 in Home Cinema Choice & What Home Cinema Lewdannie Home Cinema Magazines, Industry and Jobs 6 26-05-2004 2:05 PM
Old 15-11-2008, 6:12 PM   #1 (permalink)
My home cinema
hi
Here is my current setup so far
This is where i am going to have my projector screen on when it comes next week
This is where I have converted my draw to house to my PS3, external HDD
and Sony VPL-EW5 projector
There is a window to the left hand side but hardly lets any light in when i close the curtains.
Let me know what you think.
blingy is offline   Reply With Quote
Old 15-11-2008, 9:49 PM   #2 (permalink)
Thanks: Gave 60, Got 42
Re: My home cinema
Originally Posted by blingy View Post
hi
Converted. I love it. You mean you took the drawers out.
Good luck.
Marky P is offline   Reply With Quote
Old 16-11-2008, 8:13 AM   #3 (permalink)
Thanks: Gave 1, Got 20
Re: My home cinema
No offence mate, but it seems your setup is running on a bit of a budget there
Well here, one thing i just have to say before you go of and spend about £100 on a new projector screen, you should try out this blind first... Its honestly a very good solution for your setup and all that extra cash could go towards a stand for you AV Equipment...
ooocamperooo is offline   Reply With Quote
Old 16-11-2008, 8:48 AM   #4 (permalink)
Thanks: Gave 235, Got 213
Re: My home cinema
I would also consider painting a matt white on a screen section on the wall and painting the surrounding wall a very dark colour. This will be cheap, compromised but worthwhile IMO
Film JVC HD100,Carada BW variable masking,Denon 3800,Dacmagic, Oppo 983,Arcam AV8, P1, P7,Naim 135x4,Naim 250x2, Usher R1.5,Sonus Faber Extrema, Cremona, Elector amators, Gravis, 8033, Naim NACA5, Chord. Music Linn Sondek,Syrinx,Koetsu Red, Denon DCD3300, Croft, Tron 211, Living voice Airscout Horns
IWC Dopplel is offline   Reply With Quote
Old 16-11-2008, 8:10 PM   #5 (permalink)
Re: My home cinema
Thanks for all the advice. I am working towards a budget.
I will painting the whole white tomorrow and then putting my screen up on Tuesday. Got my screen for a special price as i know people in the AV industry.
Will let you see the results when completed.
Old 23-11-2008, 1:40 PM   #6 (permalink)
Re: My home cinema
I have now put up my projector screen but can't seem to get the correct image on the screen. it appears to be a little crooked when my PS3 is being used from HDMI. It also has another border around the original image.
my screen is a 92 inch in size.
projector in use is Sony VPL-EW5
See pic here of current image and if any of you can advise on getting the correct image on the screen?
Old 03-12-2008, 3:01 AM   #7 (permalink)
Thanks: Gave 0, Got 24
Re: My home cinema
You may be working on a limited budget but you recognized that Cinema in the Home requires more than a television can give - congrats and hoorah!!!
We tried a large tv - 56in - didn't work - tvs just can't give that Cinema in the Home epxerience - I define that as everyone in the room goes "WOW, this is just like being at the Cinema!!!"
Be sure to use an up scaling dvd player if your projector has digital (HDMI or DVI) input and your standard definition movies will look very much like HD.
So many people seem to worry more about the sound system than what Cinema is really all about which is mainly visual and needs to be "larger than life" - sound is important but, in our opinion, only about 20% of the Cinema experience and it is a support role for the screen and projector - so and again - Congratulations - you have cracked the code for Home Cinema success (and it is NOT a telly) LOL!
imjay is offline   Reply With Quote
Old 03-12-2008, 10:02 AM   #8 (permalink)
Re: My home cinema
So true!!! I always feel like im in the movie when its on a big screen projecor, But when i watch a film on my tv bahh lol
Dexxa is offline   Reply With Quote
Old 03-12-2008, 12:44 PM   #9 (permalink)
thefathacker's Avatar
Thanks: Gave 16, Got 3
Re: My home cinema
[quote=imjay;8265120]...sound is important but, in our opinion, only about 20% of the Cinema experience...quote]
Just shows that this site is all about opinion - I would have the cinematic experience far nearer 50-50 (infact exactly 50% - 50%) in terms of sound vs vision!!! Imagine no rear sound at the cinema - that to me is worth far more than 20% of the enjoyability factor!
thefathacker is offline   Reply With Quote
Old 03-12-2008, 1:16 PM   #10 (permalink)
Thanks: Gave 14, Got 7
Re: My home cinema
I presume you have tried messing with the keystone correction on your projector settings......
Anyway good luck with the project. No matter what the budget, a projector adds loads to the enjoyment of watching films at home. Have you thought of what you are going to do for sound?
See My Home Cinema Build Here
DGracey is offline   Reply With Quote
cinema, home
