Go Back   AVForums.com > Home Cinema Construction and Configuration > Home Cinema DIY
Latest AVForums Movie Reviews
Terminator Salvation Blu-ray ReviewGray Lady Down - Original Motion Picture Soundtrack CD ReviewUp Blu-ray ReviewLéon Blu-ray ReviewNear Dark Blu-ray Review
Logan's Run Blu-ray ReviewTaking of Pelham 1 2 3, The Blu-ray ReviewStar Trek Blu-ray ReviewUFC 100: Lesnar vs. Mir (2009) Blu-ray ReviewThe New York Ripper Blu-ray Review
Laminate Flooring bumper31 General Chat 11 26-10-2006 6:00 PM
Laminate flooring needs soundproofing SIRJARDI Home Cinema DIY 11 13-07-2006 9:54 AM
Laminate flooring arn Room Acoustics, Audio and Video Calibration 2 16-02-2006 6:06 AM
Laminate Flooring Drew C Home Cinema DIY 12 12-03-2004 6:04 AM
Sub & Laminate flooring... Bad mix? cerebros Subwoofers and Tactile Transducers 2 23-05-2003 2:56 AM
Old 15-11-2008, 10:27 AM   #1 (permalink)
Saldawop's Avatar
Thanks: Gave 56, Got 179
OT Laminate Flooring over concrete?
I live in a council flat (someones got to, right??).All the floors are concrete covered with tiles.Do I need a damp proof membrane? This is on the third floor.
PSN ID - LionOfTheSouthUK
Xbox 360 Gamertag - LionOfTheSouth
Saldawop is offline   Reply With Quote
Old 15-11-2008, 10:52 AM   #2 (permalink)
Thanks: Gave 1, Got 0
Re: OT Laminate Flooring over concrete?
Hi, if it is a click system laminate it will generally lay on a dpm underlay the only issue really would be sound suppression your neighbours under you will probably hear you walking about certainly to keep the peace felt pads under wood furniture you move around regulary ie dining room chairs etc
tosh28 is offline   Reply With Quote
Old 15-11-2008, 11:44 AM   #3 (permalink)
Saldawop's Avatar
Sound is not a problem...unless it is magnified by the laminate.The room below is my living room. I am guessing that DPM stands for damp proof membrane?
So you need to lay a dpm regardless of whether it is on the ground floor or not?
Old 15-11-2008, 12:56 PM   #4 (permalink)
Thanks: Gave 36, Got 176
The stuff Ive used is like very thin polystyrene and is on a role and only cheap, It cuts the chance of having any condensation build up between the concrete-tiles and laminate. But even if you don't bother with this you shouldn't have any problems in your circumstances
A Plasma n Stuff
oldnewbie is offline   Reply With Quote
Old 15-11-2008, 1:13 PM   #5 (permalink)
Thanks: Gave 35, Got 41
B&Q sell a couple of cuple that would benefit you. One is called Combilay which is a sort of foam underlay that works really well, but the product i would recommend just because i have used on many floors that i have done, is called WoodFibre, it is 6mm thick and is green fibre board and comes in packs of 19 sheets which will cover just over 9m square for about £20. Very good for noise and i have it installed over a concrete floor with tiles (ex-council flat), and i have layed engineered real wood flooring on it and works perfectly.
Only a few ideas....
KobeoneHD
Lounge: Samsung PS50B430 - Harmony ONE - Samsung BD -P1500 - Toshiba HD- EP30 - Sky HD - Mordaunt short 302's and 304C - Sony STR-DG910 - Mordaunt Short Alumni 9 sub - Mark Grant and QED cables - Apple airport express - WII
Bedroom: Samsung LE32R8 - Sky+ - KEF ci50r's - QED micro cables
KobeoneHD is offline   Reply With Quote
Old 15-11-2008, 6:00 PM   #6 (permalink)
Saldawop's Avatar
Thanks guys. One more thing.
What do I need to cut the laminate boards? a saw? or a Stanley knife? I own a Stanley knife, but not a Saw so need to have everything to hand on the day.
Can you tell I'm not too big on DIY
Old 15-11-2008, 6:22 PM   #7 (permalink)
Thanks: Gave 6, Got 8
You will need a saw/saws. Laminate is very hard. When ever I have fitted laminate floor I have used cheap £1 saws from B+Q they are crap and will only cut a coulpe of packs worth of boards but do the trick. No point in making a decent saw blunt.
MattBennett is offline   Reply With Quote
Old 15-11-2008, 6:23 PM   #8 (permalink)
Thanks: Gave 0, Got 19
I wouldn't use a knife (you'll be there all day just for one bit!) - use a saw, jigsaw or for the best results and quickness use a chopsaw with a fine tooth blade.
JuzzyD is offline   Reply With Quote
concrete, flooring, laminate
