Go Back   AVForums.com > Home Cinema Construction and Configuration > Home Cinema DIY
Latest AVForums Movie Reviews
Terminator Salvation Blu-ray ReviewNorth By Northwest (50th Anniversary Edition Blu-ray Book) Blu-ray ReviewScrooge (A Christmas Carol) Blu-ray ReviewGray Lady Down - Original Motion Picture Soundtrack CD ReviewUp Blu-ray Review
Léon Blu-ray ReviewNear Dark Blu-ray ReviewLogan's Run Blu-ray ReviewTaking of Pelham 1 2 3, The Blu-ray ReviewStar Trek Blu-ray Review
Panasonic TX37LZD85 How to use power cable when wall mounting Paul FiveTwelve Flat Screen TV Brackets and Mounts 3 28-06-2008 6:42 PM
power cable for wall mounting peterpeter AV Stands, Cabinets, Seating and Furniture 3 26-03-2006 8:19 PM
Power Outlet / Electrical Wiring advice pls xavk1 Home Cinema DIY 15 15-12-2005 6:10 PM
power cable for a wall mounted plasma? jtf Flat Screen TV Brackets and Mounts 4 21-03-2005 9:14 PM
Old 14-11-2008, 12:01 PM   #1 (permalink)
Thanks: Gave 14, Got 21
Can I power Plasma direct off electrical cable in wall?
Hi all,
I am in the process of wall mouting my plasma. Luckily I have two faceplates on the same wall, one is the switch, the other is the 3 pin mains socket.
Ideally I'd like to remove the 3pin socket, pull the cable back up the wall behind where the plasma will go and connect (using a female IEC plug) it directly to the plasma. There will be a fuse in the switch and also one in the female plug.
Here's a diagram I drew up incase I haven't explained myself very well
any problems in doing this?
Panasoinc TX-P42V10 Plasma | 500gb PS3 Slim+PlayTV | Onkyo TX-SR875 | Quad L-ites | Alphason AUR-1100B
glen8 is offline   Reply With Quote
Old 14-11-2008, 3:57 PM   #2 (permalink)
JimBobVFR400's Avatar
Thanks: Gave 22, Got 224
Re: Can I power Plasma direct off electrical cable in wall?
Looks OK to me. if my understanding of your situation is correct.
Based on the thread title I was going top suggest a fused switched spur which is what you have already going to the socket.
Jamie
Arcam AVR200, MS 500THX Speakers, Philips 42" HD screen, PS3, Philips Pronto RU950
JimBobVFR400 is offline   Reply With Quote
cable, direct, electrical, plasma, power, wall
