Hi all,
What started out as buying a new sofa has turned into decorating the entire lounge with a new suite nightmare
One of the chairs will be going where the TV is now (sat on a table stand in the corner) so we have to put the Plasma on the wall if we are to get the new suite in.
The problem (as always
) with putting the plasma on the wall is the viewing angles from the sofa. The person sat on the right hand side of the sofa will be watching the plasma at an extreme angle. Therefore I had the idea today of using one of those swing arm mounts where you can lift the tv away from the wall and tilt it to either the right or the left. Since the mount is going on plasterboard will it be safe? Luckily the wall is an outside one so can drill into the thermalite blocks, or go deep into the bricks if needed. It's a new build house.
The last thing I want on Christmas Day is swinging the TV out for all the family and seeing it fall onto the floor
Has anyone used one of these mounts, especially on a plasterboard wall
also, can anyone recommend a company who specialize in flat screen installations?
Thanks very much
