Go Back   AVForums.com > Home Cinema Construction and Configuration > Home Cinema DIY
Latest AVForums Movie Reviews
Terminator Salvation Blu-ray ReviewGray Lady Down - Original Motion Picture Soundtrack CD ReviewUp Blu-ray ReviewLéon Blu-ray ReviewNear Dark Blu-ray Review
Logan's Run Blu-ray ReviewTaking of Pelham 1 2 3, The Blu-ray ReviewStar Trek Blu-ray ReviewUFC 100: Lesnar vs. Mir (2009) Blu-ray ReviewThe New York Ripper Blu-ray Review
OK to Leave ON ? chriswhiteuk Subwoofers and Tactile Transducers 3 06-10-2008 9:07 PM
leave amp on? audiojunkie Audio Processors and Power Amps 5 15-10-2006 10:58 PM
Sky HD Box - Leave On or Off ? TimmyH Sky HD 11 20-06-2006 2:42 PM
To Leave On Or Not To Leave On, That Is The Question TurnipFarmer Hi Fi Systems and Separates 6 05-11-2005 12:45 AM
Leave on, or not leave on! cheeseburger Arcam Owners' Forum 7 23-02-2004 10:50 AM
Old 10-11-2008, 11:24 AM   #1 (permalink)
Thanks: Gave 2, Got 2
What do i leave in the room?
Hi there,
I love seeing other members rooms when you cant see much AV equipment in the room.
I have an opportunity to move as much AV equipment into another room (under stairs), I'm not sure how much to move. Definately Sky HD & PC. Can't move PS3.
What about the receiver? will this be more hassle than its worth.
I will be controlling via Harmony remote over IR extender.
Has anyone else moved the receiver out of the room?
DrewIOW is offline   Reply With Quote
Old 10-11-2008, 5:28 PM   #2 (permalink)
Thanks: Gave 22, Got 91
Re: What do i leave in the room?
Why cant you move the PS3?
AV:Samsung 19" (Kitchen) 32" (Bedroom) 40" (Lounge), Panasonic PT-AX200, SkyHD, Pioneer 868, Onkyo 605, MS902i/905/302, BK XLS200, Harmony 885 x2, Squeezebox Duet, HTPC Gaming:360 Elite PS3 Wii Modded Xbox Flashed PSP
My old bedroom setup My new home cinema and multiroom - DIY work in progress
MitsiTurbo is online now   Reply With Quote
Old 11-11-2008, 12:11 AM   #3 (permalink)
thefathacker's Avatar
Thanks: Gave 16, Got 3
Drew,
My gear isn't out of the room - but it may as well be as it's hidden away behind the floating wall and as is your plan, controlled by an 895 using RF to IR. With regard to moving the PS3, as MitsiTurbo says - why not? If controlling it is an issue - I've seen one of these that I'm thinking of getting. Those more in the know than me will, I am sure, be able to suggest alternatives.
thefathacker is offline   Reply With Quote
Old 11-11-2008, 3:50 PM   #4 (permalink)
I have been told that the harmony controls dont support the bluetooth needed forthe PS3, although the device you mention looks like a perfect solution.
The only reason for not moving the PS3 is I thought it will be hassle walking into another room to put in a bluray or game, but then if i have to get up to walk to the unit anyway...
just lazy i suppose.
Old 12-11-2008, 12:01 AM   #5 (permalink)
The Prof.'s Avatar
Thanks: Gave 1, Got 39
Originally Posted by DrewIOW View Post
Hi there,
I moved all my gear (including the AVR) into the room next door..and I use an IR extender with Harmony remote...
Works perfectly..
Prof..
My Cinema
http://picasaweb.google.com/farmerNB/MyCinema#
The Prof. is offline   Reply With Quote
DrewIOW (12-11-2008)
Old 29-11-2008, 10:31 PM   #6 (permalink)
Thanks: Gave 15, Got 5
what ir extender do you guys use that works fine with a harmony.
thanks
theodotcom is offline   Reply With Quote
Old 30-11-2008, 12:43 AM   #7 (permalink)
thanks
I use the bundled one that is currently available from pixmania.
Old 30-11-2008, 12:59 AM   #8 (permalink)
The Prof.'s Avatar
thanks
If you type in "IR Extender" in search on the Pixmania website, you'll see the type of unit I'm using..
Prof..
My Cinema
leave, room
