Go Back   AVForums.com > Home Cinema Construction and Configuration > Home Cinema DIY
Latest AVForums Movie Reviews
Terminator Salvation Blu-ray ReviewNorth By Northwest (50th Anniversary Edition Blu-ray Book) Blu-ray ReviewScrooge (A Christmas Carol) Blu-ray ReviewGray Lady Down - Original Motion Picture Soundtrack CD ReviewUp Blu-ray Review
Léon Blu-ray ReviewNear Dark Blu-ray ReviewLogan's Run Blu-ray ReviewTaking of Pelham 1 2 3, The Blu-ray ReviewStar Trek Blu-ray Review
Wood finish svs tubes Andywilliams Subwoofers and Tactile Transducers 9 14-10-2007 5:16 AM
Anyone with a wood finish SVS out there? galewis1 Subwoofers and Tactile Transducers 16 27-11-2004 1:19 AM
real wood or silver finish? Stevie S Speakers 4 17-09-2003 12:32 PM
Rel Strata III (Wood finish) OnTheFly Home Cinema Hardware Bargains and Discount Codes 0 08-05-2003 11:15 PM
Old 30-10-2008, 9:52 AM   #1 (permalink)
Thanks: Gave 4, Got 1
home made sub box requires black wood finish!??
hi guys im m aking my own box for my 12" sub, it will be MDF in construction, but i want it to look the same as the rest of my speakers
they have a black wood finish
is this melamine??
where can i buy the product i need from?
cheers
Tony
scaredpassenger is offline   Reply With Quote
Old 30-10-2008, 2:21 PM   #2 (permalink)
Thanks: Gave 61, Got 49
Re: home made sub box requires black wood finish!??
You can get veneered MDF with "real" wood finishes, available in oak ash etc, would just need a black stain and finish applied.
Most good wood yards should sell it.
Melamine normaly has a chipboard core which isnt as strong as MDF.
Just a ginger mutt called Alby now
jro7563 is offline   Reply With Quote
scaredpassenger (30-10-2008)
Old 30-10-2008, 2:44 PM   #3 (permalink)
I'll give my local freindly wood yard a ring!
I'll let everyone know how i get on!!
Cheers JR0!!
Old 31-10-2008, 8:44 AM   #4 (permalink)
is there not any iron on stuff available to do this kind of stuff?
its gonna be hidden away but will be just viewable so if its glimpsed i want it to at least look a little similar to the rest of my speakers?
Old 31-10-2008, 3:44 PM   #5 (permalink)
You can get an iron on veneer for the edges but i think the widest is 50mm
some veneer products here
Another possibility would be a vinyl wood effect wrap like Fablon, some of those look quite realistic.
Old 31-10-2008, 3:51 PM   #6 (permalink)
try these ppl. they have a good range. i think that your other units will prob be black ash effect.
T. Driscoll (Veneers) Ltd. - Ash Veneer
joinerdan is offline   Reply With Quote
Old 02-11-2008, 7:02 AM   #7 (permalink)
thanks guys i couldnt see anything on that first sight that was physically black, T driscoll didnt appear to have any prices i will give them a buzz on monday!!
Old 02-11-2008, 8:59 AM   #8 (permalink)
Paul D's Avatar
Thanks: Gave 61, Got 113
You can buy veneered MDF.
You could then lightly spray/paint the veneer to keep the grain.
You would then need to varnish to finish etc.
If you have already started, then you could try HERE for some veneers.
Or this is the melamine product you need. (click here)
You will need to search a bit to get it over here etc...
AKA "fulabeer"
Paul D is offline   Reply With Quote
black, box, finish, home, made, requires, wood
