Hey all,
Here is my proposed method that I'll be using to mount my plasma when it arrives. I just have 1 problem, so if anyone can see a better way of doing things, chime in!
Right, the wall is dot and dab plasterboard (40mm), breeze block, cavity and then the second layer of breeze block. The problem is we have the main electric feed coming in from outside to the house directly behind where I want to wall-mount the plasma. I am 99% certain that the feed runs in the cavity. I've checked using a cable detector and there's no constant "flatline" tone, but it does beep (which backs up my theory).
Can anyone see a problem drilling in to the first layer of the breeze
(not going through to the second layer of block) and hanging the TV using 6x M8 rawlbolts with long bolts. I will probably cut out the plasterboard to the size of the bracket then pad out the gap with MDF/chipboard which I will also no-more-nails to the breeze behind.
Anyway, enough explaining.. I've mocked up a picture (cross-section) to explain what I'm on about a bit better.
Anyone see anything immediately dodgy? I'll probably pin a layer of lead to the MDF to help shield from the interference, but I could always stand-mount the TV if this seems a bit dodgy.
I'll post a step-by-step guide when I've done it.. as there were a lot of results in the searches I did, but nothing covering a TV this size or the electric feed problem.
