Go Back   AVForums.com > Home Cinema Construction and Configuration > Home Cinema DIY
Latest AVForums Movie Reviews
Gray Lady Down - Original Motion Picture Soundtrack CD ReviewUp Blu-ray ReviewLéon Blu-ray ReviewNear Dark Blu-ray ReviewLogan's Run Blu-ray Review
Taking of Pelham 1 2 3, The Blu-ray ReviewStar Trek Blu-ray ReviewUFC 100: Lesnar vs. Mir (2009) Blu-ray ReviewThe New York Ripper Blu-ray ReviewHeat Blu-ray Review
Neon Lighting setup - recommendations? SniperChris Home Automation, Lighting, Security, Heating and Cooling 2 14-01-2008 3:21 PM
In Ceiling Speakers? Recommendations Please! SoltoN Speakers 4 21-12-2007 12:56 AM
In-Ceiling Speaker Recommendations? n.simpson Speakers 14 02-06-2007 6:56 PM
high room(3.3m) false ceiling DIY fritsiboy Home Cinema DIY 2 06-10-2005 5:08 PM
remote lighting and blinds for cinema room-recommendations? NeilTh Home Automation, Lighting, Security, Heating and Cooling 5 20-09-2005 11:02 PM
Old 28-10-2008, 1:33 PM   #1 (permalink)
Dexter Grim's Avatar
Thanks: Gave 0, Got 3
False Ceiling, lighting recommendations wanted.
I'm thinking on putting up a false ceiling and having lighting around the edge to give a light effect around the top edge of the room with the light source hidden between the original ceiling and the false ceiling.
i.e. the false ceiling is an inch or two lower than the original ceilng and stops 3 or 4 inches from the walls
Can anyone recommend any suitable lights.
Thanks,
Dex
Dexter Grim is offline   Reply With Quote
Old 28-10-2008, 1:50 PM   #2 (permalink)
Assured Advertiser
dj-dulux's Avatar
Thanks: Gave 8, Got 101
Re: False Ceiling, lighting recommendations wanted.
Could try cold cathode, a very underused lighting technology in the home. Keep it to low voltage so no electrical issues, costs around £45 / meter including ballasts which can be dimmed on normal dimmers.
Dupe...
105dB at 3m with 2W... without line arrays or compression drivers
Life's better when it's wired! - Wired Life
Proud to be an AVForums sponsor and assured advertiser
dj-dulux is offline   Reply With Quote
Old 28-10-2008, 3:04 PM   #3 (permalink)
Thanks: Gave 22, Got 91
Or could try the good ol' rope light which is £1.80 a metre.
AV:Samsung 19" (Kitchen) 32" (Bedroom) 40" (Lounge), Panasonic PT-AX200, SkyHD, Pioneer 868, Onkyo 605, MS902i/905/302, BK XLS200, Harmony 885 x2, Squeezebox Duet, HTPC Gaming:360 Elite PS3 Wii Modded Xbox Flashed PSP
My old bedroom setup My new home cinema and multiroom - DIY work in progress
MitsiTurbo is offline   Reply With Quote
Old 28-10-2008, 3:55 PM   #4 (permalink)
Assured Advertiser
dj-dulux's Avatar
Very true, depends what effect the OP wants.
Dupe...
Old 28-10-2008, 4:54 PM   #5 (permalink)
My requirements are:
Continuous light effect - no breaks in the light
Little / no heat generated
Cheap
Still deciding if to go single colour or mutli colour
or IR/RF on/off / dim
Old 28-10-2008, 8:01 PM   #6 (permalink)
Dupe...
Sorry, my post was aimed at the OP Dupe, just realised that it sounded like I was rubbishing your idea which I didnt mean it to
Dexter,
Just to give you a bit more info on the rope light, you can get it in lengths of up to 45m, is mains powered and emits low heat. Its also dimmable, however the LED version is not. You can use something like a varilight dimmer for IR control. Cost has gone up to £1.95 a metre unfortunately or £63/45m.
This is the effect you get:
Dimmed:
And finally, a link to the site where you can get it:
Duralite Rope Lights
Old 28-10-2008, 8:41 PM   #7 (permalink)
Assured Advertiser
dj-dulux's Avatar
No probs, no offence taken, the rope light is hard to beat on a cost and ease of installation, the main advantage of cold cathode is that it is much brighter, comes in many colours and could be used to light the room rather than just using as an effect. I am actually installing some in my house at the mo, so will post up some info when done, maybe 4 to 6 weeks.
Dupe...
Old 29-10-2008, 11:19 AM   #8 (permalink)
Cheers guys, the rope lights looks like what I'm after.
Thanks for the pics and link.
Old 29-10-2008, 6:04 PM   #9 (permalink)
No probs. There are more pics and info on how I did it in my thread here if you are interested:
Here we go...
ceiling, false, lighting, recommendations, wanted
