Go Back   AVForums.com > Home Cinema Construction and Configuration > Home Cinema DIY
Latest AVForums Movie Reviews
My Bloody Valentine - Special Edition Blu-ray ReviewThe Universe: Complete Season One Blu-ray ReviewTerminator Salvation Blu-ray Review20th Century Boys: Chapter 2 - The Last Hope Blu-ray ReviewNorth By Northwest (50th Anniversary Edition Blu-ray Book) Blu-ray Review
Scrooge (A Christmas Carol) Blu-ray ReviewGray Lady Down - Original Motion Picture Soundtrack CD ReviewUp Blu-ray ReviewLéon Blu-ray ReviewNear Dark Blu-ray Review
Audio Newbie Looking for Advice on a £500 5.1 setup sstorrow Speakers 15 13-06-2008 9:32 AM
newbie needs advice on LCD TV setup tamw LCD Televisions 2 28-12-2007 3:49 PM
Advice on number and type of leads for new lounge setup diggerbarnes AV Amplifiers and Receivers 7 14-08-2007 3:32 PM
New setup advice for a newbie please Fast500 LCD Televisions 0 05-12-2005 3:29 AM
Plasma Setup Newbie Advice miked1900 Plasma Televisions 0 05-07-2005 2:36 PM
Old 26-08-2008, 11:32 AM   #1 (permalink)
Thanks: Gave 2, Got 0
Help/Advice Please Lounge Setup!! Newbie!!
Please can I have your advice/help on the best way to get this to work.
plan of room
What I really need to know is the best option to run the cables from the AV Cabinet (Equipment: Sky+, Xbox 360, Amp, DVD Player) behind the Recliner and this has been located there because that is were the 2 Sky+ inputs com into the house.
Looking at a wall mounted Panasonic TH-42PZ80B.
Does this plasma have an external tuner with it as well that I will need to find room for?
Thanks in advance.
burnrubber is offline   Reply With Quote
Old 30-08-2008, 9:37 PM   #2 (permalink)
Re: Help/Advice Please Lounge Setup!! Newbie!!
Basically what would be the easiest way to run the cables form the AV Cabinet to the TV?
Old 30-08-2008, 9:45 PM   #3 (permalink)
Thanks: Gave 139, Got 168
What sort of flooring do you have because that might be the tidiest way to go about it. Either channel in your cables if it's concrete or under boards if it's boards. If not that you might think about coving and run the cables round the ceiling. Less tidy would be to put trunking all the way round but the door to the right makes that not a very descreet option.
This Weeks TV Listing
enablerbro1 is offline   Reply With Quote
Old 31-08-2008, 4:21 AM   #4 (permalink)
We have wooden flooring down with coving surround, also what is the best option to control all of the Av Components from that layout?
Old 31-08-2008, 7:05 AM   #5 (permalink)
Thanks: Gave 22, Got 91
You say that the equipment has to go behind the recliner because of the cables from the dish, but would you actually prefer it somewhere else? Im just thinking that it would be alot easier and cheaper to extend the dish cables to a new location rather than having to buy longer scarts, component leads etc to run the equipment to a new location.
AV:Samsung 19" (Kitchen) 32" (Bedroom) 40" (Lounge), Panasonic PT-AX200, SkyHD, Pioneer 868, Onkyo 605, MS902i/905/302, BK XLS200, Harmony 885 x2, Squeezebox Duet, HTPC Gaming:360 Elite PS3 Wii Modded Xbox Flashed PSP
My old bedroom setup My new home cinema and multiroom - DIY work in progress
MitsiTurbo is offline   Reply With Quote
Old 31-08-2008, 3:04 PM   #6 (permalink)
Very good point.
Old 31-08-2008, 6:34 PM   #7 (permalink)
Thanks good point, Have been thinking about all scenario's really.
The only reason for the change is that we currently have a Double Oppli were the sofa is at the moment with all the AV equipment on it.
We have a baby on they way and was just really thinking ahead of when it starts to crawl/touch/walk etc
I was going to build a floating wall as per the plan and mount the plasma on it and just 1 idea was to have the AV equipment in that corner near the sky+ inputs.
If the Av equipment is over in that corner would the remotes work OK for example, seeing as we would be facing the TV.
We could have the AV equipment in a cabinet with say glass doors under the TV.
That is why I was asking for help, there is alot of more experienced people on here and just after some advice of what would work best.
Old 01-09-2008, 8:14 AM   #8 (permalink)
I guess, depending on your AVR you could have just a single HDMI running to the TV under the floorboards and an aerial for the Freeview. I can't see there being any problem with your remotes working with the equipment in the corner.
I had a quick look and it has an integrated Freeview decoder, according to DIgital Direct.
Babies, before potty training they should get not posting jammy toast into the DVD player training. Either that or genetically engineered AV eqpt friendly babies. :D
Old 01-09-2008, 8:18 AM   #9 (permalink)
Liam_G's Avatar
Thanks: Gave 10, Got 17
a bit off subject but what website did you use to do that sketch up? i forgotten it!
Liam_G is offline   Reply With Quote
Old 01-09-2008, 9:07 AM   #10 (permalink)
Magslad's Avatar
Thanks: Gave 145, Got 145
Generally speaking the best place to put your AV equipment (cabling-wise) is close to the TV, so if this is an option I would look into it. The reason being that if you have the kit in a far corner, you will have a range of cables that you need to run fairly long lengths of (potentially scart, component, HDMI, optical etc) all of which can get quite expensive. However if you have all of the kit near the TV you can use shorter/standard lengths and it is only speaker cables (assuming you have 5.1/7.1) that would need to be run round the room - which you would need to do wherever you position your amp. It will also make it easier when you inevitably decide to upgrade something and find it needs a different cable.
Having been through the baby/toddler stage (and thankfully past it now!) with 2 kids, they will get everywhere anyway so wherever you place the kit it won't matter - some sort of glass-fronted cabinet definitely a good idea, and in some way better if it's by the TV as at least you can see them going towards it rather than them attacking it in the corner whilst you're distracted watching TV!
With respect to the 42PZ80B, this is the plasma I have so can confirm it definitely has integrated Freeview tuner.
Hope this helps.
Nikon D80; Nikon VRII 18-200mm & 50mm 1.8; Tamron 90mm Macro; Sigma 50-500mm EX DG
Onkyo TX-SR606; KEF 5005.2's; Panny 42PZ80B/BD30/DMR-EX78; NAD 304; Tannoy 607's; Harmony One
My loft conversion home cinema thread
Magslad is offline   Reply With Quote
Old 01-09-2008, 7:01 PM   #11 (permalink)
I used this website to sketch a basic planhttp://housetohome.icovia.com/icovia.aspx
Old 01-09-2008, 7:08 PM   #12 (permalink)
Hope this helps.
Excellent Thanks for you input, That is perhaps what I will have to look at I do have 5.1 and the cables are getting rather expensive already so might have to modify the Duo-Oppli I already have to be a bit cild proof (easier said than done)
Thanks again.
Old 01-09-2008, 7:11 PM   #13 (permalink)
Hope this helps.
Also while looking at your loft conversion, what did you use for the floor in your loft conversion, looks great and I was thinking of doing this in the near future.
Thanks in advance.
Old 01-09-2008, 7:26 PM   #14 (permalink)
Magslad's Avatar
Thanks in advance
Sorry, I think I'm being thick here in answering your question, but the floor isn't down in the loft yet. The construction of the loft extension is pretty standard - two big steels along each side of the loft, then joists hung across between the steels. They have just started putting down chipboard for the floor, and we will then carpet over that.
If I've missed the point of your question let me know and I'll do my best to answer it better!
help or advice, lounge, newbie, setup
