Go Back   AVForums.com > Home Cinema Construction and Configuration > Home Cinema DIY
Latest AVForums Movie Reviews
Terminator Salvation Blu-ray ReviewGray Lady Down - Original Motion Picture Soundtrack CD ReviewUp Blu-ray ReviewLéon Blu-ray ReviewNear Dark Blu-ray Review
Logan's Run Blu-ray ReviewTaking of Pelham 1 2 3, The Blu-ray ReviewStar Trek Blu-ray ReviewUFC 100: Lesnar vs. Mir (2009) Blu-ray ReviewThe New York Ripper Blu-ray Review
Speaker Wall Plates Matt F Home Cinema DIY 13 01-04-2007 11:46 AM
Wall plates for speaker cables Dave Weystoner Interconnects, Speaker Cables and Switches 2 19-12-2006 12:59 PM
Speaker wall plates Nabs Arcam Owners' Forum 2 28-10-2006 9:51 AM
Where to source speaker wall plates etc? schroedm Home Cinema DIY 9 01-08-2006 3:39 PM
Speaker Wall Plates 1ofaKind Interconnects, Speaker Cables and Switches 2 17-08-2004 1:03 PM
Old 25-08-2008, 1:47 PM   #1 (permalink)
Thanks: Gave 0, Got 3
Making speaker wall plates?
After some clarification of what I am doing is OK? I have drilled a satin finish blanking plate and fixed two binding posts and solders the + an - speaker cable to the binding posts. My question is will the + and - stay separate? or will the metal plate cause interference?
Hope that makes sense.
Danny
wilding is offline   Reply With Quote
Old 25-08-2008, 1:49 PM   #2 (permalink)
RobM83's Avatar
Thanks: Gave 155, Got 557
Re: Making speaker wall plates?
By the sounds of it, you have just joined together the +'ve and -'ve posts. If they are all connected to one piece of metal, they are all connected. That's not something I'd recommend doing!
Forum Rules - Forum Search
My opinions are my own and are not necessarily representative of AVForums
RobM83 is offline   Reply With Quote
Old 25-08-2008, 3:53 PM   #3 (permalink)
Thanks: Gave 6, Got 59
It all depends on which binding posts you're using, and what they are made of.
RichardK is offline   Reply With Quote
Old 25-08-2008, 5:08 PM   #4 (permalink)
Miniholic's Avatar
Thanks: Gave 516, Got 386
As Richard says, it depends which ones you are using. I made my own plates too, using sockets rather than binding posts. In my case, and this goes for most of the options I looked at, the posts have a plastic sleeve that isolates it from the plate. You can see some detail of how I made mine in the posts below.
http://www.avforums.com/forums/showp...&postcount=414
http://www.avforums.com/forums/showp...&postcount=426
I sourced my fittings from CPC with the blank plates coming from Screwfix.
Sony HW10, Denon 3910, 3806. Toshiba HD-EP30. Pioneer CLD-D925, TF100GB. Panasonic BD35, NS830 VCR.
Carada Criterion 92" screen. PS2. Wii. B&W 602.5, LCR60, 601s3, 600s3 & ASW675. Harmony 1000.
My DVD’s The Miniplex Skip to the end...
Miniholic is offline   Reply With Quote
Old 25-08-2008, 5:17 PM   #5 (permalink)
Thanks for the help guys, looks like mine will be useless as I have used the brass binding posts Is it possible to get plastic washers? as I prefer the brass binding posts to the plastic.
Danny
Old 25-08-2008, 5:32 PM   #6 (permalink)
Miniholic's Avatar
Do yours not have any type of insulation on them? Do you have a link to them?
Try this link. http://cpc.farnell.com/jsp/search/re...ana+socket&Ntx=
If it doesn't work search for item no's AV15599 & AV15600, both are gold and have isolating washers.
Old 25-08-2008, 5:41 PM   #7 (permalink)
Hi looking at the link mine are similar to http://cpc.farnell.com/AV15601/cable...ignal-psg02053
looking at the ones you recomend, would I be able to use some nylon washers to isolate them?
Danny
Old 25-08-2008, 5:52 PM   #8 (permalink)
Miniholic's Avatar
Can't see why not, just make sure that where the binding post passes through the plate is full insulated so that it cannot short out.
Old 26-08-2008, 8:33 AM   #9 (permalink)
Good point, I will run some insulation tape around the thread of the post to make sure.
Danny
making, plates, speaker, wall
