Go Back   AVForums.com > Home Cinema Construction and Configuration > Home Cinema DIY
Latest AVForums Movie Reviews
Gray Lady Down - Original Motion Picture Soundtrack CD ReviewUp Blu-ray ReviewLéon Blu-ray ReviewNear Dark Blu-ray ReviewLogan's Run Blu-ray Review
Taking of Pelham 1 2 3, The Blu-ray ReviewStar Trek Blu-ray ReviewUFC 100: Lesnar vs. Mir (2009) Blu-ray ReviewThe New York Ripper Blu-ray ReviewHeat Blu-ray Review
Wall mounting a 42" plasma on to a stud wall SimonH Home Cinema DIY 3 11-01-2008 5:39 PM
Flush mounting Plasma in new stud wall - suggestions please! Reg_the_Veg Home Cinema DIY 5 17-03-2007 10:04 PM
aluminium frame stud plasterboard wall plasma mounting help madman1178 Custom Installations and Installers 4 20-12-2006 12:44 AM
Mounting a plasma IN a stud wall damolong Flat Screen TV Brackets and Mounts 3 17-11-2005 3:45 PM
Plasma mounting on Stud Wall BoomBoom Flat Screen TV Brackets and Mounts 2 04-10-2004 9:31 AM
Old 25-08-2008, 11:42 AM   #1 (permalink)
plasma mounting to stud wall
right about to purchase a lovely pio 5090 to go in my attic/games room
anyhow its only a stud wall with no brickwork behind it.
how do you make sure the tv is lined up correctly before you go fixing the bracket to the wall?
Just I have to cut out a section of the plasterboard to re-inforce the wall ( by fixing some lengths of 4"/2 across the uprights which are already in place.
but im alittle un nervy about how to get the correct position for the tv? its just one side is a sloping wall and lets just the ceiling isnt excatly sqaure to the eye. but inplace at the moment I have a massive canvas which went on using a level and it looks spot on.
just need some advise for gettign the right position and whehter my idea about re-inforceing the stud wall is spot on?
is there anything else I should worry about? look out for or even include so it goes straight forward without being a cock up! I was thinknig of once I have added more timber to replaster and then fit the wall bracket, but where is the best place to leave a hole for the wires to go through?
need advise
that is the wall inwhich it will be mounted-can see what I meen abotu the sloping wall
durbin is offline   Reply With Quote
Old 25-08-2008, 7:32 PM   #2 (permalink)
Thanks: Gave 50, Got 18
Re: plasma mounting to stud wall
These links may be helpful:
http://www.wikihow.com/Wall-Mount-a-Plasma
or
http://www.hometheaterblog.com/homet...lcd-or-plasma/
Good Luck!
Joebo is offline   Reply With Quote
Old 26-08-2008, 1:59 PM   #3 (permalink)
Thanks: Gave 2, Got 13
Some newer mounts have a swivel on them. Ostensibly, it's so you can change the orientation from horizontal to vertical - but it perfectly covers up any defects in your original mounting.
You can also get mounts with "tilt". It's meant so you can mount high and angle the screen down. On your wall, you could use it the opposite way up. That way the tilted screen would be perpendicular to the floor.
TiVo + 250GB + Cachecard + Mode 0 ~ PJ-TX100 ~ Greywolf Screen ~ Xbox + Xenium + XBMC ~ Xebian NAS ~ Wii ~ AOC L32W581B ~ 7.1 Surround Sound ~ Understanding Girlfriend fiancée wife!
terryeden is offline   Reply With Quote
Old 27-08-2008, 7:26 PM   #4 (permalink)
dodfaefife's Avatar
Thanks: Gave 5, Got 10
As a quicky why not tape out your TV shape on the wall with masking tape or whatever and live with it for a day or so to make sure you're happy with position. Joebo links look good for the rest.
Pioneer 506XDE, SonyKDL-40D3500, JVC DLA-HD1, 106" DRH, Onkyo TX-SR875, B&W601, B&WCC6, B&WLM1, Yamaha-YST300, SkyHD Multi, PS3, XBox360, Harmony-1000, MacMini
My home cinema project
dodfaefife is offline   Reply With Quote
Old 28-08-2008, 8:07 PM   #5 (permalink)
thanks for hte links- was alot of help
though with the tilt mount would that be suitable for that wall? I meen it recommend on one of those sites to put the tv no higher than 40"-45" off the floor.
how much are these tilt mounts and do they actually ofer better viewing?
thanks for the replies
mounting, plasma, stud, wall
