Go Back   AVForums.com > Home Cinema Construction and Configuration > Home Cinema DIY
Latest AVForums Movie Reviews
Terminator Salvation Blu-ray ReviewGray Lady Down - Original Motion Picture Soundtrack CD ReviewUp Blu-ray ReviewLéon Blu-ray ReviewNear Dark Blu-ray Review
Logan's Run Blu-ray ReviewTaking of Pelham 1 2 3, The Blu-ray ReviewStar Trek Blu-ray ReviewUFC 100: Lesnar vs. Mir (2009) Blu-ray ReviewThe New York Ripper Blu-ray Review
Mounting AV Sales Flush Wall Mount tigermad Home Cinema DIY 1 13-04-2007 6:41 PM
Plasma flush with new 15" false wall - which bracket? zedzed Flat Screen TV Brackets and Mounts 1 28-02-2007 3:26 PM
Mounting a plasma flush to the wall Siamese Cat Plasma Televisions 5 23-10-2006 4:41 PM
Mounting a TH42PV500 on a wall, is it possible to flush mount it ? Taz69 Flat Screen TV Brackets and Mounts 3 09-11-2005 12:04 PM
Sinking 436XDE flush into false wall, feasible? Dave Williamson Plasma Televisions 5 14-10-2005 4:01 PM
Old 21-08-2008, 10:52 AM   #1 (permalink)
Thanks: Gave 1, Got 2
Flush mounting LCD tv in false wall... heat problems?
I was wondering, is it ok to
a) mount the lcd tv onto the main wall
b) use MDF (or similar) to 'build' the wall forward so that the front of the TV is flush with the wall?
The concern I have is the heat that the tv will give off essentially 'inside' the fake wall area. The area will be large (roof to floor) and wide (about 3 times the width of the tv) but could the heat build up, and what could I do to stop that happening?
essentially I want to mount the tv so it looks / is resessed into the wall so that the projector screen can come down in front of it rather than having to mount the projector screen forward on the roof to let it get past the screen.
Any thoughts, comments etc would be fab
Thanks in advance
David
itrends is offline   Reply With Quote
Old 23-08-2008, 8:01 AM   #2 (permalink)
Re: Flush mounting LCD tv in false wall... heat problems?
Hi there,
I don't think that you will have a problem. I've done the same thing with my 43" plasma. Even after a few hours viewing there is no real build up of heat - warm air yes - but nothing to right home about.
The attahced picture isn't the best but there is about a 4 inch deep resess that the TV sits in so that the front of the panel is flush. The TV is fully enclosed and there is mood lighting fixed around the inside of the frame. There is about a 2 inch gap around the edge of the screen. MDF is standard 12mm
Sorry I don't have any better pictures
Hope this helps
inkywinkypinky is offline   Reply With Quote
Old 23-08-2008, 9:26 AM   #3 (permalink)
Thank you very much. Just the answer I was looking for
Your setup looks great too.
false, flush, heat, lcd, mounting, problems, wall
