Go Back   AVForums.com > Home Cinema Construction and Configuration > Home Cinema DIY
Latest AVForums Movie Reviews
Gray Lady Down - Original Motion Picture Soundtrack CD ReviewUp Blu-ray ReviewLéon Blu-ray ReviewNear Dark Blu-ray ReviewLogan's Run Blu-ray Review
Taking of Pelham 1 2 3, The Blu-ray ReviewStar Trek Blu-ray ReviewUFC 100: Lesnar vs. Mir (2009) Blu-ray ReviewThe New York Ripper Blu-ray ReviewHeat Blu-ray Review
BK XLS200 sub, where to buy thebassman Subwoofers and Tactile Transducers 7 29-02-2008 4:20 PM
Difference between XLS200 and XLS200-DF? gm0x45 Subwoofers and Tactile Transducers 2 11-09-2006 12:44 PM
Bk Xls200 GFS AV Subwoofers and Tactile Transducers 6 01-03-2005 8:06 PM
Big Box XLS200? Roam Subwoofers and Tactile Transducers 18 20-02-2005 7:59 PM
XLS200-DF/xls200 or used thekingbeyond Subwoofers and Tactile Transducers 1 16-11-2004 5:52 PM
Old 18-08-2008, 10:35 PM   #1 (permalink)
Thanks: Gave 7, Got 8
xls200 pr
I have asked BK today via email.. but what do you guys reckon adding a pr to an xls200 will do? I have plotted curves on winisd and it seems to improve extension but I am an absolute novice when it comes to winisd.
johndoe1 is offline   Reply With Quote
Old 18-08-2008, 11:01 PM   #2 (permalink)
Badger0-0's Avatar
Thanks: Gave 178, Got 1,228
Re: xls200 pr
Unless you can do it extremely cheaply (I'm guessing you would need to up the amp too), I really can't see the point mate.
I suppose it depends what you're after, but if it's bigger sound from a small box, you might do better to sell your sub and buy an SVS SB12+ or similar.
If size is not a problem, just go for a Monolith or SVS PB/C or similar.
Here's something that might interest you, but you've most likely read it seeing as you're contemplating going down that road;
BK XLS-300/pr
ASTON VILLA
Never bite the hand that feeds you. It's usually your own.
Badger0-0 is offline   Reply With Quote
johndoe1 (19-08-2008)
Old 19-08-2008, 6:09 AM   #3 (permalink)
Thanks: Gave 0, Got 15
Re: xls200 pr
when adding a PR to a xls200 you need a bigger cabinet
the xls200 uses 18 liters and with a PR you need 31 liters
have a look here
http://www.vikash.info/audio/xls10/
Onkyo 605, toshiba EP35, sony bdp350, Amphion center, Skandia drop surrounds, Seas DIY fronts BK xls300P/R, BK monolith
subwoofers , anti mode 8033
Sony 40 inch bravia LCD
asdonk is offline   Reply With Quote
Old 19-08-2008, 7:22 AM   #4 (permalink)
Re: xls200 pr
have a look here
agree with everything you both have said do I.
I have an svs pb10 but it is too big, hell even the xls300pr is a bit too wide for me.
So diy seems to be the way to go - my box will be approx wxhxd 12.5x12.5x17, to match my allcam 60" plasma stand. I will paint it gloss black to match also.
I guestimate that my internal volume should be near 30litres.
I may go for 2 x pr??
The driver will be downward facing - the pr's will be on the sides. Total stealth.
Amp - suggestions? (want to keep project to £300 in total)
xls10 - £60 (target price)
xls10pr - can't find a deal on this so it's looking like £50 from bk
amp - help!!! but looking at about £120
materials - £70
or! should I stop being silly and just buy a sb12+
Old 19-08-2008, 9:23 AM   #5 (permalink)
danmc_82's Avatar
Thanks: Gave 338, Got 178
Re: xls200 pr
Is there no way you can accomodate an xls300?
Thing is, if you spend £300 on stuff for your xls200 and it sounds crap, you've just blown £589 on speaker cones and firewood. I'd leave well alone.
Kit List: SkyHD, PS3 160GB, Yamaha RX-V1900, Monitor Audio RS6, RSLCR, RSFX, XLS 300PR, Sony 40KDLW2000 LCD.
PSN: danmc_82
danmc_82 is offline   Reply With Quote
Old 19-08-2008, 10:59 AM   #6 (permalink)
Re: xls200 pr
too wide - it's 400wide. I can only accomodate 320. But i can increase depth to 430.
I don't have a sub at the moment - I have sold my svs pb10.
parts will be around £300 and that will include 2 x pr's increasing output over an xls300.
If it sounds cr4p then I won't have done my homework correctly and that will be my bad!
Old 19-08-2008, 11:13 AM   #7 (permalink)
Thanks: Gave 69, Got 127
Re: xls200 pr
You were asking about getting an SB12+, but that is 14" wide, so is too wide.
What about placing it elsewhere? or is that not a viable option?
Samsung LE40M87BD | Onkyo TX-SR875 | SVS SBS-01 | SVS PB13U | Virgin V+ | Panasonic DMR-EX75EB | Xbox 360 | PS3 | Toshiba HD-EP35 | Behringer DSP1124P | Marantz CD63SE
Andori is offline   Reply With Quote
Old 19-08-2008, 11:14 AM   #8 (permalink)
Re: xls200 pr
try to redesign the cabinet, but just stick to the 31 lites
with 1 PR the xls10 plus PR will go to 20 hz -3db
the same as the PB10 which is great for movies
Old 19-08-2008, 12:20 PM   #9 (permalink)
Conspicuous Member
recruit's Avatar
Thanks: Gave 427, Got 509
Re: xls200 pr
moved as requested to DIY section.
Antec BD HTPC - Oppo BDP 83 - Arcam FMJ CD17 - 46" LCD 1080p - Arcam FMJ AV888 - Rotel RMB-1575 - M&K S150THX LCR - M&K CS29's - M&K MX5100SF...
recruit is offline   Reply With Quote
Old 19-08-2008, 12:50 PM   #10 (permalink)
danmc_82's Avatar
Re: xls200 pr
Good idea, build your own box and put the speakers and amp in yourself. Probably the cheapest way to do it.
PSN: danmc_82
Old 19-08-2008, 12:54 PM   #11 (permalink)
Re: xls200 pr
I remember reading that they are only 13.5" wide - that is near to the max.
has anyone got any suggestions for an amp plate around the £100 mark?
xls200
