Go Back   AVForums.com > Home Cinema Construction and Configuration > Home Cinema DIY
Latest AVForums Movie Reviews
Gray Lady Down - Original Motion Picture Soundtrack CD ReviewUp Blu-ray ReviewLéon Blu-ray ReviewNear Dark Blu-ray ReviewLogan's Run Blu-ray Review
Taking of Pelham 1 2 3, The Blu-ray ReviewStar Trek Blu-ray ReviewUFC 100: Lesnar vs. Mir (2009) Blu-ray ReviewThe New York Ripper Blu-ray ReviewHeat Blu-ray Review
Old 16-08-2008, 12:36 PM   #1 (permalink)
Thanks: Gave 42, Got 44
Dining Room / Lounge Project
Hi all,
been reading (and contributing where I can) for some time... so it's about time that I made my own DIY thread..
The first round of DIY is already complete, this consisted of decorating the dining room, lounge, hallway, landing and new baby nursery... Too much in one go you think??? Me too!
Anyway, the plan was to take out 32" LCD from the lounge and put it on the wall in the dining room. Also, I had a set of Bose Acoustimass 10 speakers which I'd fitted into the bedroom when I decorated in there, but as yet had never connected them up! So they were earmarked for moving into the dining room also.
Problem is with my decorating is that I don't do "decorating" unless it involves a big hammer and usually some extreme work to some degree (for decorating anyway).
I won't bother you with the rooms, and just stick to the dining room for this thread (as I couldnt justify an AV requirements in the other rooms!).
The next stage is to move into the lounge, you'll see from the pictures that the need to redecorate the lounge is a "necessary" progression from the dining room works!
I'm just about to start some shopping with regards to the lounge and will be asking for some of you good people's advice, so all input will be received with thanks.
Barry
Pics to follow...
bardel is offline   Reply With Quote
Old 16-08-2008, 12:43 PM   #2 (permalink)
Thanks: Gave 139, Got 168
Re: 1 down, 1 to go...
Pulls up chair.
This Weeks TV Listing
enablerbro1 is offline   Reply With Quote
Old 16-08-2008, 12:53 PM   #3 (permalink)
Ok, unfortunately, I don't appear to have much in the way of a "before" picture of the dining room, so the pics will have to start at the stage where we started tearing down....
The "wooden" thing in the corner, is a boxed in section carrying all the plumbing between the ground and 1st floors.
Old 16-08-2008, 1:01 PM   #4 (permalink)
Then there's the awful arch and artexed surrounding... that has to go...
Old 16-08-2008, 1:07 PM   #5 (permalink)
Here is the edge of the chimney stack which runs through the middle of the house... It's been blocked off ever since we've been here and I took the stack off the roof, loft and first floor last year...
A sneaky little look through the hole and having already taken the landing floor up, revealed that there would be no reason why the chimney stack can't come out.
So... out with the ceiling then (it had quite a few drops in it and I figured since there'd be holes at either corner, I'd just replace the lot...
Old 16-08-2008, 1:12 PM   #6 (permalink)
Next up, out with the bay window, to be replaced by a french door...
Quite pleased with the effect this has on the room, the lounge had french doors at the back, but we never use them, and we envisaged the dining room being used as a day room once the baby arrived and my wife would be at home.
Old 16-08-2008, 1:13 PM   #7 (permalink)
Thanks: Gave 2, Got 0
Ain't you missing something?
Pics?
abs_2006 is offline   Reply With Quote
Old 16-08-2008, 1:20 PM   #8 (permalink)
So then, out with the chimney stack...
Here you'll see start to see why the lounge "has" to be done...
Acro's in the lounge next and out with the fireplace...
Say hello to the lounge... Oh you can see that I decided to replace all the flooring too The floor joists are at 24" centres and the chipboard was way too bouncy on it, especially as I am laying solid oak wood flooring on it!
Old 16-08-2008, 1:29 PM   #9 (permalink)
New wall going back in... As you can see, the void from the chimney flue has been carefully chosen as the new location for my AV equipment. With our first baby on it's way, I knew I needed to get this stuff locked away!!!
Old 16-08-2008, 1:36 PM   #10 (permalink)
Pics?
Not just me then, good, I thought I was going picture blind.
Old 16-08-2008, 1:54 PM   #11 (permalink)
Pics?
Sorry guys, being a bit numpty with the picture posting, first time I've uploaded pics to a forum, you wouldn't believe computer programming is my trade would you?!!
Hopefully you can see them now?
Old 16-08-2008, 1:58 PM   #12 (permalink)
Thanks: Gave 7, Got 30
i can only see 4... but loving the destruction...
i might have to lift my floor now, as ours is bouncy and i know it has chipboard flooring... wonder if its 24"on centers too.
Rupees_al
"Time flies like an arrow, fruit flies like a banana"
rupees_al is offline   Reply With Quote
Old 16-08-2008, 1:59 PM   #13 (permalink)
Back to the dining room, we wanted to put the TV in one of two places, being the indecisive type (well the other half is), I decided to cable both locations...
I dont appear to have taken a picture of the other location, but I can prove it's there, coz that's where we decided to put the TV in the end, as the final pictures will demonstrate!
Old 16-08-2008, 2:00 PM   #14 (permalink)
New sub flooring with freshly suspended insulation. New flooring was laid in 18mm MDF which is amazingly more flex resistant than the chipboard that was down before.
Old 16-08-2008, 2:03 PM   #15 (permalink)
Chimney void all boxed in and finished off. We made a feature alcove in the upper part which I've put a spotlight in.
