Go Back   AVForums.com > Home Cinema Construction and Configuration > Home Cinema DIY
Latest AVForums Movie Reviews
Terminator Salvation Blu-ray ReviewScrooge (A Christmas Carol) Blu-ray ReviewGray Lady Down - Original Motion Picture Soundtrack CD ReviewUp Blu-ray ReviewLéon Blu-ray Review
Near Dark Blu-ray ReviewLogan's Run Blu-ray ReviewTaking of Pelham 1 2 3, The Blu-ray ReviewStar Trek Blu-ray ReviewUFC 100: Lesnar vs. Mir (2009) Blu-ray Review
Farily Simple Question: Using a Satellite Box w/ Cable rockfan0005 Satellite TV 3 25-07-2008 10:00 PM
Simple Question - Please recommend which speaker cable? reidy_uk2001 Interconnects, Speaker Cables and Switches 12 16-07-2007 4:48 PM
Quick and simple Sub cable question.. docfeelgood Interconnects, Speaker Cables and Switches 1 08-09-2006 12:40 PM
Dead Simple DVI cable question kev^ Interconnects, Speaker Cables and Switches 2 14-10-2005 6:38 PM
Simple Freeview Cable Question Kopite4Ever Freeview 5 15-05-2005 9:05 PM
Old 14-08-2008, 11:25 AM   #1 (permalink)
Thanks: Gave 8, Got 15
Simple Question - Should We Cable Cat6?
If cabling a new build, would it be wise to use CAT6 cable rather than cat5? Are there any drawbacks (aside from cost).
Are there any brands to avoid, or any which are recognised as being good quality?
Many thanks.
There are 10 kinds of people in this world, those
who understand binary, and those who don't!
hamd01 is offline   Reply With Quote
Old 14-08-2008, 11:46 AM   #2 (permalink)
Thanks: Gave 5, Got 6
Re: Simple Question - Should We Cable Cat6?
Well cost is one of the big factors plus need cat6 cable "is faster" but only if the need is there cat5 is fast enough for 99% of applications and cat5 is alot cheaper to!
Johnny.A is offline   Reply With Quote
Old 14-08-2008, 1:33 PM   #3 (permalink)
Thanks: Gave 0, Got 2
If you wish to blow a few more bucks on performance, either put it into the processors of the routers, switches or firewalls and given yourself a faster network that way.
A common misconception about faster and capacity, is that 1gb is faster than 100mbits, from an end-users point of view, its not.
Finally, beg/borrow/steal or insist on having your cables tested.. Soooo many installations with duff cabling at some point and as its operating at 25% it can fool some detectors and end-users...
Pioneer Lover - PDP-LX508D (Not Calibrated yet ) BDP-LX70a HDMI Everywhere! B&W XT4 Wharfdale 8.1 as surrounds Chord Speaker Cables DVD-757 'Scouring ebay for a B&W Centre Speaker to match the XT4's'
Boyzer is offline   Reply With Quote
Old 14-08-2008, 2:39 PM   #4 (permalink)
Thanks: Gave 3, Got 1
If cost is no issuse then going for cat6 will help you run future spec speeds....but check out cat6e which doesnt have the 55m limit for data.
Imp
impossible_ is offline   Reply With Quote
Old 14-08-2008, 3:44 PM   #5 (permalink)
I'm not quite sure I follow: Surely if the end users desktops have Gb NICs, then having 1Gb connections rather than 100Mbits its going to offer a significant performance boost.
I'm estimating that around £300 worth of CAT6e will cable the house. Given that its backward compatible with 5e, I cant see any reason why I shouldnt install it....I dont want to be in a position in 10 years where Im streaming god knows what here and there and wish I had 6e in place.
Old 14-08-2008, 5:17 PM   #6 (permalink)
Well its up to you and your cash if it makes you happy buy the cat6e your cash!
Old 14-08-2008, 10:01 PM   #7 (permalink)
GavT's Avatar
Thanks: Gave 17, Got 11
Bear in mind CAT6 is more difficult to terminate than CAT5. I understand that CAT6 is only required over very long runs if you're aiming for 1000Mbps network speeds. Normally CAT5 would suffice.
Eyes: Optoma H78, HK 2550S, Denon 2105, Mission 77 series, Paradigm PS1000
Ears: B&W CDM1NT, Musical Fidelity A3.2, Arcam Alpha 7SE
GavT is offline   Reply With Quote
Old 15-08-2008, 9:31 AM   #8 (permalink)
Thanks: Gave 20, Got 16
Cat6 has the same length limits as Cat5e, however you can run with faster speed. If you want to future proof your house then Cat6 is the way to go but if there are no major developments in wireless/wired speeds then Cat5e running at 1GB should be plenty for your house and streaming needs.
Oh and I'm not so sure it's more difficult to terminate, I've not noticed any difference between the two other than Cat6 is a bigger cable.
Bear in mind that Cat6 can be used in speeds up to 10GBase-T however the quality of the cable will play a big part on the speed you will be able to run. Make sure you use a good quality shielded cable and you should be ok.
I do 100% agree with Boyzer have your cables installed by a professional company or get them tested if you run them yourself.
Skars is offline   Reply With Quote
Old 15-08-2008, 10:57 AM   #9 (permalink)
Cat 5e has a limit of 328 feet, and from what I have read cat 6e has a limit of 1000 feet.
Old 15-08-2008, 4:00 PM   #10 (permalink)
As with all cables defined by ANSI/TIA/EIA-568-B, the maximum allowed length of a Cat-6 horizontal cable is 100 meters 330 ft so unless your house is huge then I wouldn't worry too much about the cable length
And if your house is that big hell I would just go for fibre instead :P
Not wanting to pick a fight but do you have a link to where it says the standard is now 1000' I would like to have a read, knowledge is power etc
Old 15-08-2008, 8:43 PM   #11 (permalink)
I can dig the article out where I read the full cat6 standard (I was at work at the time).....but heres one from a quick google;
http://www.tomshardware.co.uk/forum/...quot-long-quot
Old 16-08-2008, 9:00 AM   #12 (permalink)
Well, obviously every cable run that you do is entirely dependant on the environment you run in. However I don't know if the 630m segment length is believable. As far as I was aware the ANSI standard was 100m per network segment even some of the posters on your link say 100m so I'm more confused than ever now
Old 16-08-2008, 10:52 AM   #13 (permalink)
Thanks: Gave 69, Got 138
Cat5E and Cat6 are cable standards. 100Mb & 1000Mb Ethernet are networking standards. Running 10/100/1000Mb Ethernet over Cat5E or Cat6 gives you a length limit of 100m.
Cat6 needs a lot more care when installing than Cat5E, e.g. crimping, twisting, bend radii and termination, and all your modules/patch panels need to be Cat6 too.
One very important point is if you haven't tested your installation using a proper Cat5E/Cat6 tester, as apposed to a modtap tester, then it hasn't actually been proven at either standard. Yes, it might work, but not to it's best ability or for your future needs.
Would I install Cat6 for a new build? Not sure really: as Gb is really over kill at home anyway, a nice to have obviously, and that is no problem with Cat5E. If it was only 10-15% extra cost then probably.
Kris.
KrisLee is offline   Reply With Quote
Old 17-08-2008, 9:09 PM   #14 (permalink)
vex
Assured Advertiser
Thanks: Gave 9, Got 181
If you or your electrician is doing the install then I would hazard a guess that the performance of CAT6 will be no better than CAT5e.
Regardless of the proposed performance it is a lot less tollerent to the abuses of a domestic install.
We still install CAT5e in properties and IMO with the amount of legacy CAT5e out there there should be alot of performance improvements to come.
V.
Be careful out there forumites - 89% of statistics are made up.
vex is online now   Reply With Quote
Old 17-08-2008, 10:12 PM   #15 (permalink)
Thanks: Gave 27, Got 23
Whatever you do make sure you are actually getting the speed you can. Having cat5e or 6 is very different from getting (1)gigabit transfers rates.
I just wired up my house and couldnt think of a reason to justify the cost of 6 over 5e.
dmce is offline   Reply With Quote
cable, cat6, question, simple
