Go Back   AVForums.com > Home Cinema Construction and Configuration > Home Cinema DIY
Latest AVForums Movie Reviews
Gray Lady Down - Original Motion Picture Soundtrack CD ReviewUp Blu-ray ReviewLéon Blu-ray ReviewNear Dark Blu-ray ReviewLogan's Run Blu-ray Review
Taking of Pelham 1 2 3, The Blu-ray ReviewStar Trek Blu-ray ReviewUFC 100: Lesnar vs. Mir (2009) Blu-ray ReviewThe New York Ripper Blu-ray ReviewHeat Blu-ray Review
Extrending Cat5 over mains point-to-point shl Networking and NAS 2 27-01-2008 4:58 PM
AV Over CAT5 obrien.james CAT5 Cabling 5 31-05-2007 8:57 AM
CAT5 next to Mains paul1967 CAT5 Cabling 2 27-10-2006 9:45 AM
Cat5 for 5.1? mowbli CAT5 Cabling 0 10-01-2005 1:42 PM
Cat5 mains cable? daninthemix CAT5 Cabling 6 06-08-2003 8:32 AM
Old 12-08-2008, 9:31 AM   #1 (permalink)
Thanks: Gave 10, Got 4
Cat5 near mains
I'm running CAT5 around my house and at some point in the run to 50% of my rooms the only way I can route the cables are under the floor boards of the first floor. On our landing where I want to route the cables there are quite a lot of mains cable's routed here too. It would make my CAT5 run parallel to the mains for just under 3 meters.
What can I do to minimise any interference in this section of the run ?
The cable is standard UTP solid core.
Any advice would be great.
Thanks,
Marvin.
Panasonic PWD8, Yamaha RX-V757SE, Sony DVP-S725, Sky+, 3 Canton CD360F's LCR, Canton CD310F rears, SVS PB10-ISD
marvinwright1 is offline   Reply With Quote
Old 12-08-2008, 9:44 AM   #2 (permalink)
Thanks: Gave 61, Got 49
Re: Cat5 near mains
Im no expert here, but ive just run some CAT5-E and like you mine runs very close and next to mains voltage cables under the floorboards and i havent had any problems at all.
jro7563 is offline   Reply With Quote
Old 12-08-2008, 10:54 AM   #3 (permalink)
MasterYoda's Avatar
Thanks: Gave 12, Got 8
Re: Cat5 near mains
there really won't be a problem
Master Yoda
MasterYoda is offline   Reply With Quote
Old 12-08-2008, 11:04 AM   #4 (permalink)
Re: Cat5 near mains
Thanks guys, I searched on google about this and there are mixed opinions.
Guess I'd be real unlucky if it caused me any problem.
Cheers,
Marvin.
Old 12-08-2008, 11:35 AM   #5 (permalink)
Thanks: Gave 69, Got 138
Re: Cat5 near mains
Morning,
Strictly there should be a 50mm separation between power and cat5. Cat5 can be run perpendicular to power. In your case I'd risk it as it's a only a small parallel run and you've got a very small network.
Regards,
Kris.
KrisLee is offline   Reply With Quote
Old 12-08-2008, 12:02 PM   #6 (permalink)
Re: Cat5 near mains
I'll certainly be able to manage 50mm separation.
I'm sure it'll be fine
Old 12-08-2008, 12:06 PM   #7 (permalink)
Assured Advertiser
dj-dulux's Avatar
Thanks: Gave 8, Got 101
Re: Cat5 near mains
As well as the 50mm rule, don't forget to follow the regs for the drilling of holes through beams etc. Don't want the floor collapsing!
Dupe...
105dB at 3m with 2W... without line arrays or compression drivers
Life's better when it's wired! - Wired Life
Proud to be an AVForums sponsor and assured advertiser
dj-dulux is offline   Reply With Quote
Old 12-08-2008, 2:08 PM   #8 (permalink)
Thanks: Gave 22, Got 107
Re: Cat5 near mains
Could always use shielded just for the extra piece of mind?
37" LCD , Hyundai A321 (with 1:1 for bedroom), Denon 1507, Tannoy EFX5.1, Xbox 360, Popcornhour A-100 & C200, Sky+HD, Wii, Harmony
daniel_owen_uk is offline   Reply With Quote
Old 12-08-2008, 3:22 PM   #9 (permalink)
Thanks: Gave 0, Got 2
Re: Cat5 near mains
Lots of office infrastructure is put in using 3 part compartment dado trunking... And in my experience, most of the cabling has been put in the middle section, ie. the mains and the cat5e are running side by side, in many cases, with less than 50mm between them..
Which is mad, bearing mind the cost of the trunking!!
Similarly, i've seen hundreds of central office 'poles' which feed power, voice and data, sockes, which although i've not been in them, are probably no more than 2 inches wider than any single mains socket.
In short, keep them apart as much as you can, but I wouldn't worry, but do beg/borrow or steal a cat5e tester, which will highlight any weakness in your cabling... Never mind mains... Pinching, damage or just poor wiring at the ends (i.e. you might suffer from Near End Cross Talk) Which would mean you wouldn't get your full access and/or syncronise use of the 1gb, or 100mbs...
Pioneer Lover - PDP-LX508D (Not Calibrated yet ) BDP-LX70a HDMI Everywhere! B&W XT4 Wharfdale 8.1 as surrounds Chord Speaker Cables DVD-757 'Scouring ebay for a B&W Centre Speaker to match the XT4's'
Boyzer is offline   Reply With Quote
Old 12-08-2008, 3:50 PM   #10 (permalink)
Re: Cat5 near mains
Thanks a lot for all the replies. I have a basic cable tester, I know a network guy, I may be able to borrow a better tester.
Cheers,
Marvin.
Old 12-08-2008, 7:18 PM   #11 (permalink)
Re: Cat5 near mains
50mm gap between high voltage and low voltage is all thats needed, that is the regs. if u can get more then so be it i wouldn't worry. i've seen loads and loads of low voltage stuff laying over swa and not having problems, and even getting passed at the end of jobs as nobody checks it anyway most of the time.
incentive is offline   Reply With Quote
Old 14-08-2008, 2:48 PM   #12 (permalink)
Thanks: Gave 1, Got 0
Re: Cat5 near mains
Last summer I ran a network connection next to a 410v power cable outside. I was worried about the provide, but it did 100mb day in/day out for a week.
Imp
Impossible is offline   Reply With Quote
Old 14-08-2008, 9:12 PM   #13 (permalink)
Thanks: Gave 27, Got 18
Re: Cat5 near mains
The 50mm ruling is difficult to think of a 50mm gap, where in the trunking example quoted, you'll find that the 50mm gap is the physical distance of the trunking "wall", which is typically 25mm deep, hence the 50mm distance.
Hope this helps.
Photos: http://picasaweb.google.com/thompma30/
thompma is offline   Reply With Quote
cat5, mains
