Go Back   AVForums.com > Home Cinema Construction and Configuration > Home Cinema DIY
Latest AVForums Movie Reviews
Up Blu-ray ReviewLéon Blu-ray ReviewNear Dark Blu-ray ReviewLogan's Run Blu-ray ReviewTaking of Pelham 1 2 3, The Blu-ray Review
Star Trek Blu-ray ReviewUFC 100: Lesnar vs. Mir (2009) Blu-ray ReviewThe New York Ripper Blu-ray ReviewHeat Blu-ray ReviewMoon Blu-ray Review
Wall mount height ? Scott 2802 Home Cinema DIY 10 06-10-2007 8:25 AM
What height for Wall mount of 42" LCD leighster AV Stands, Cabinets, Seating and Furniture 4 06-03-2007 6:54 AM
wall mount height tevez Plasma Televisions 1 15-02-2007 8:50 PM
What height from the floor do you wall mount? williams_1980 Flat Screen TV Brackets and Mounts 2 19-11-2006 5:57 PM
What height to wall mount? Scott_Mac Flat Screen TV Brackets and Mounts 3 19-02-2006 9:22 PM
Old 11-08-2008, 10:10 PM   #1 (permalink)
loz
Thanks: Gave 259, Got 757
What height for a wall mount?
Just started redecorating, and in the process moving the TV from a stand to a wall mount.
I put the mount up, but its in the middle of the wall vertically.
It is higher up than it was on the stand, but not as high as you often see people place them on walls.
My wife thought it looked a little odd and was expecting me to put it higher, but more from expectation from other wall mounts she had seen I guess. Asthetically, I guess it does seem a little strange being bang in the centre of the wall.
Whereas, where it is, it seems perfect for when you are sat down as you down have to look up at all.
I can easily move the mount - the plasterer isn't due for a couple of weeks yet. Or should I leave it where it is?
loz is offline   Reply With Quote
Old 11-08-2008, 10:57 PM   #2 (permalink)
Thanks: Gave 139, Got 168
Re: What height for a wall mount?
That would do for me.
This Weeks TV Listing
enablerbro1 is offline   Reply With Quote
Old 13-08-2008, 12:32 PM   #3 (permalink)
Thanks: Gave 4, Got 5
Perfect height is when the middle of the screen is level with your eyeline when sat down in your seat.
My plasma is a little higher than eyeline, but only by about 10cm.
southdownswolf is offline   Reply With Quote
Old 13-08-2008, 1:13 PM   #4 (permalink)
Thanks: Gave 22, Got 107
Stick cardboard same size as tv to the wall, sit and watch for ten minutes, if happy fit tv.
Where it's comfy is more important than where SWMBO want's it
37" LCD , Hyundai A321 (with 1:1 for bedroom), Denon 1507, Tannoy EFX5.1, Xbox 360, Popcornhour A-100 & C200, Sky+HD, Wii, Harmony
daniel_owen_uk is offline   Reply With Quote
Old 13-08-2008, 2:19 PM   #5 (permalink)
Assured Advertiser
hornydragon's Avatar
Thanks: Gave 95, Got 1,332
Depends on your room and seating height i have seen some far far too high, never been asked to raise a screen but asked to lower them before mine is 800mm from floor normal is between 800 and 1100 (higher the further away you are)
Life's better when it's wired! - Wired Life
Proud to be an AVForums sponsor and assured advertiser
hornydragon is offline   Reply With Quote
Old 13-08-2008, 2:55 PM   #6 (permalink)
loz
The screen (not the rest of the TV) is 920mm from the floor. So that seems to fit.
height, mount, wall
