Originally Posted by radders89 Is it safe / possible to have a 37" LCD fitted above a working 'real' (wood burning) fireplace?
I believe the chimney breast is brick built but dont know much more that that.
I assume fitting a suitable bracket to the wall isnt a problem however im concerned about heat rising from the fire and also about how best to route the cables. I guess the cable could only be routed after creating a cutout in the brick / plaster?
I have searched the forums but have only really come across suggestions for gas / electric fires....
Any suggestions would be great!
Thanks |
Stick a thermometer up against the wall and check the temp when a roaring fire is going,thgen check in the manual if its within the safe operating tempertures.
I have it done,I havent lit the fire yet but I plan to.
