Go Back   AVForums.com > Home Cinema Construction and Configuration > Home Cinema DIY
Latest AVForums Movie Reviews
Gray Lady Down - Original Motion Picture Soundtrack CD ReviewUp Blu-ray ReviewLéon Blu-ray ReviewNear Dark Blu-ray ReviewLogan's Run Blu-ray Review
Taking of Pelham 1 2 3, The Blu-ray ReviewStar Trek Blu-ray ReviewUFC 100: Lesnar vs. Mir (2009) Blu-ray ReviewThe New York Ripper Blu-ray ReviewHeat Blu-ray Review
Putting Wires in the walls kstone Home Cinema DIY 17 23-03-2008 11:46 AM
Putting Wires in the Walls (Future Proof) kstone Custom Installations and Installers 39 26-02-2008 4:48 PM
Hiding wires in walls with future proofing techno79 Home Cinema DIY 10 03-04-2007 4:50 PM
A quick question about wires behind walls SpencerUp Home Cinema DIY 8 12-02-2007 9:35 PM
Cable advice before chasing wires in walls nokmond Plasma Televisions 13 17-11-2006 12:03 AM
Old 06-08-2008, 12:02 PM   #1 (permalink)
Thanks: Gave 3, Got 4
Question Ideas for wires coming out of walls
Im sure there is a far more tech way of describing what im after but im a supernoob so apologies in advance!!
Basically i have run all my cables (hdmi/ speaker/ power) under my floors/ in my wall and i have them all coming out at one point at the base of the wall behind where my amp will be sitting. This is fine for the moment as i am yet to put skirting down. When i do (put skirting down), i need these wires to come out at a central point and I would like to make this as tidy as possible.
I have considered installing banana clip sockets for the speaker cable but ideally i would like to avoid breaking the direct connections i currently have between my amp and my speakers for the sake of quality.
I guess what i am looking for is some sort of letterbox type fascia to put on my wall then i can pull all the cables up through that and feed them to my amp. Does this kind of thing exist purpose built or should i literally use a small letterbox?
Any help/ suggestions would be great!!
hope this makes sence!!
Panasonic 42PZ70b - Xbox Elite - Sky HD - Yamaha DSP-AX763 receiver - B & W MT speakers (front and centre) - Realistic (rears) - Rel Quake Sub - 1973 Sansui speakers (rears) - Bose companion 3 - MacBook Pro
MY HT "BUILD" IN PROGRESS
alfromscotland is offline   Reply With Quote
Old 06-08-2008, 12:12 PM   #2 (permalink)
Thanks: Gave 12, Got 8
Re: Ideas for wires coming out of walls
I think you can buy the letterbox 'brushes' on their own. Get some of those and a couple of blank power point fascias cut to the required size and there you go.
TV: Toshiba 32WL66 AMP: Onkyo 605 SOURCES: V+, Pioneer DV400, Vista Media Centre PC running Media Portal SPEAKERS ZONE 1 (Lounge): Jamo A102's SPEAKERS ZONE 2 (Kitchen): 6.5" 100W Ceiling Mounted
pmanson is offline   Reply With Quote
Old 06-08-2008, 12:28 PM   #3 (permalink)
MarkP80's Avatar
Thanks: Gave 92, Got 76
Have a look here
MarkP
My Cinema and the Bar!
MarkP80 is offline   Reply With Quote
alfromscotland (06-08-2008)
Old 06-08-2008, 12:46 PM   #4 (permalink)
Originally Posted by MarkP80 View Post
Have a look here
MarkP
Perrrrrfect...although im not too sure if i can get a plug through there (The 5m power cable i bought has a sealed connection so i cant just unwire the plug and put the wires through.
Old 06-08-2008, 1:03 PM   #5 (permalink)
Thanks: Gave 37, Got 22
Hi, could you not just cut the plug off and rewire another one on??
dreamboat10 is offline   Reply With Quote
Old 06-08-2008, 1:08 PM   #6 (permalink)
GuyVXT's Avatar
Thanks: Gave 7, Got 1
cant you chop the plug off, thread it through the other way and then reconnect the plug?
GuyVXT is offline   Reply With Quote
Old 06-08-2008, 1:28 PM   #7 (permalink)
Well yes, but can i be arsed??
Id rather not have to
Old 06-08-2008, 2:23 PM   #8 (permalink)
JimBobVFR400's Avatar
Thanks: Gave 22, Got 224
I've used the brush letterbox covers you can buy from Focus/B&Q/Homebase etc very cheaply.
Excellent for the job and big enough to slot a plug through with a bit of jiggling.
Also looking at the ones recommended by Mark above. I think you'd probably get a plug through there, if you thread it through earth pin first and jiggle it you might/should be OK.
Jamie
Arcam AVR200, MS 500THX Speakers, Philips 42" HD screen, PS3, Philips Pronto RU950
JimBobVFR400 is offline   Reply With Quote
Old 06-08-2008, 2:32 PM   #9 (permalink)
I love the confidence of that sentence maybe you should have added a perhaps in there just to completely remove any potential liability
I think i will have a look in B&Q, its not that im a stingy aberdonian or anything, its just £33 for a hole? seems excessive
Cheers for the advice
Old 06-08-2008, 3:43 PM   #10 (permalink)
Thanks: Gave 0, Got 2
I used one of these in my ceiling yesterday to feed the cable through for my projector. Two minute job to cut the hole. The inner face comes out to allow plugs through. Cost £2.99.
julianashcroft is offline   Reply With Quote
Old 06-08-2008, 4:04 PM   #11 (permalink)
Excuse my ignorance, where do you pick these up? I guess i could steal one off my desk at work but it doesnt have the brushes. Looks like a great cheap good looking solution!
Old 07-08-2008, 10:50 AM   #12 (permalink)
Ebay.
Lots here:
http://stores.ebay.co.uk/Fitted-Room...QQftidZ2QQtZkm
alfromscotland (07-08-2008)
Old 07-08-2008, 6:52 PM   #13 (permalink)
Franco50's Avatar
Thanks: Gave 34, Got 38
Al, you can get a 13 amp plug through those brush faceplates as I have just fitted one this week. I just bought the single gang size and I have fed the following through it:
1 x power lead
1 x ariel lead
2 x hdmi cables
1 x scart cable
1 x phono lead
1 x component lead
3 x speaker cables
Equipment: Panasonic TH37PX80, Humax T9200 PVR, Pioneer DV-490 DVD, Yamaha RX-V359 Amp, Mordaunt Short MS302, MS304 and MS309 speakers
Franco50 is offline   Reply With Quote
coming, ideas, walls, wires
