Go Back   AVForums.com > Home Cinema Construction and Configuration > Home Cinema DIY
Latest AVForums Movie Reviews
Terminator Salvation Blu-ray ReviewGray Lady Down - Original Motion Picture Soundtrack CD ReviewUp Blu-ray ReviewLéon Blu-ray ReviewNear Dark Blu-ray Review
Logan's Run Blu-ray ReviewTaking of Pelham 1 2 3, The Blu-ray ReviewStar Trek Blu-ray ReviewUFC 100: Lesnar vs. Mir (2009) Blu-ray ReviewThe New York Ripper Blu-ray Review
Damp walls where to go for advice. GrahamC General Chat 13 30-07-2007 10:22 AM
Damp Amp dirkdiggler147 AV Amplifiers and Receivers 2 29-12-2006 6:03 PM
Damp GJC General Chat 4 19-12-2006 12:54 PM
LCD and Damp antoeknee LCD Televisions 3 03-10-2006 7:38 PM
Just a little damp Sgt.Colon Music 6 09-12-2002 3:07 PM
Old 06-08-2008, 10:57 AM   #1 (permalink)
woody23's Avatar
Thanks: Gave 15, Got 54
Advice needed - Damp
Hi guys
I am just about to bite off more than i can chew and convert my cellar to a home cinema room
Currently the cellar is quite cold and damp and was wondering what advice you can offer to help
Obviously i need it 100% dry before i start major work on the cellar and was wondering if any of you had used a cheapish company or recommend a very good DIY kit?
i can upload pics if needed?
hope you can help and appreciate any of your comments
woody23 is online now   Reply With Quote
Old 06-08-2008, 11:32 AM   #2 (permalink)
Thanks: Gave 481, Got 254
Re: Advice needed - Damp
You'll need a dehumidifier to help dry the whole room out.
When we had a washing machine spill in our utility room it took over a month to get the concrete floor to an acceptable level of dryness before the replacement vinyl could be fitted.
Visually, it looked ok the next day.
The Insurance company company paid an additional £1 per day towards the electricity costs for running the dehumidifier.
With a cellar it may never dry out fully unless you get damp proofing to the outside areas of the walls which would be a major job.
I'd certainly get professional advice.
Sorry, but good luck
Pioneer KRP600A, Denon A1HDA, Panasonic BD35, Panasonic PX80, Panasonic DMR-E500, 2x Kef Ref 2.2's, Kef Ref 200c, 2x Kef Q2DS's, 2x Kef Q60's, SVS PB12-Ultra/2, Velodyne SMS-1.
Nikon D300, 18-200mm, 17-55mm, TC-14E, Sigma 10-20mm, SB900.
Flickr
Steve N is offline   Reply With Quote
Old 06-08-2008, 11:41 AM   #3 (permalink)
woody23's Avatar
This is what i am thinking, looks like its going to cost me a lot though
thanks for the comments
Old 06-08-2008, 12:50 PM   #4 (permalink)
Mickus's Avatar
Thanks: Gave 239, Got 324
You could damp-proof from the inside via a water-proof membrane / floating wall / floor solution. Don't think it's a DIY solution though and have no idea on cost.
http://www.newton-membranes.co.uk/
Mickus is offline   Reply With Quote
Old 06-08-2008, 11:47 PM   #5 (permalink)
Thanks: Gave 12, Got 26
its not a diy job,you need to tank the whole basement.
The damp dopesnt just dry out,it continuously comes in.
So its not just a case of drying it out.
velvitjester is offline   Reply With Quote
Old 07-08-2008, 5:48 AM   #6 (permalink)
woody23's Avatar
tank? tell me more......
Old 07-08-2008, 11:23 AM   #7 (permalink)
Thanks: Gave 0, Got 3
As above you need to tank the room using a membrane, have a search for my ongoing cellar conversion thread it shows some pictures of what is meant by tanking. I used the Olydroyd membrane.
HTH Danny
wilding is offline   Reply With Quote
Old 07-08-2008, 11:24 AM   #8 (permalink)
Also I did a DIY job and it is very simple
Old 07-08-2008, 12:19 PM   #9 (permalink)
inzaman's Avatar
Thanks: Gave 91, Got 365
Check out the FAQS at the top of this section as there ar esome cellar conversions in there, my own included. This will give you an idea as to the magnitude of such a conversion
Visit my Home Cinema here
inzaman is offline   Reply With Quote
Old 07-08-2008, 5:21 PM   #10 (permalink)
woody23's Avatar
Thanks to inzaman and wilding
Some great work you have done and totally inspired me to do the same
I phoned today to ask for some quotes, the best i could find was around £1200 to Tank the whole cellar (comes with a 25 year warrenty)
Does that sound good?
Old 08-08-2008, 11:02 AM   #11 (permalink)
Sounds to cheap to be honest. It cost me more than that just for the membrane and plugs etc....What size room is it? are you goning to use a sump/pump incase any water gets in?
Danny
Old 08-08-2008, 6:05 PM   #12 (permalink)
Thanks: Gave 0, Got 5
just done my garage the same way an it cost me 2100 for the room to be made inside the garage
the membrane was i think 1200 gauge for the whole room inc floor and ceiling
i was a little worried when i started and then i was thinking well thair is no going back and all the stuff was orderd
dont forget it isnt just lining out the celler thair will be the cost of sound proofing the plastering the electric switches and cabling poss door to fit
i dont want to put you off atall just dont do it on the cheap as it will bite you on the ass if you dont do it right
total cost for the garage is about 4000 pounds to me its worth it as i like gaming and movies
just ake sure you dont put money into a bottomless pit
good luck mate i hope you do the job and it come out a nice set up that you are happy with
daveblade is offline   Reply With Quote
Old 08-08-2008, 7:59 PM   #13 (permalink)
woody23's Avatar
Yeah i understand that there is going to be a lot of added costs
I have only just finished out lounge and thats turned out so so nicely (can upload pics if wanted)
I have the official damp proof company coming to give me a written quote later next week
I wont be cutting any corners when doing this conversion and if it means waiting a few more months to save a few more pennies then thats what i will do, the last thing i want to do is ruin a beautiful house that we have only bought just under a year ago
I will make sure that i update this thread as much as i can with updates and lots of photos to show the developments made
The size of the room is 3.5 meters by 5 meters
Thanks again to all the replies so far.......
advice, damp, needed
