Go Back   AVForums.com > Home Cinema Construction and Configuration > Home Cinema DIY
Latest AVForums Movie Reviews
Terminator Salvation Blu-ray ReviewGray Lady Down - Original Motion Picture Soundtrack CD ReviewUp Blu-ray ReviewLéon Blu-ray ReviewNear Dark Blu-ray Review
Logan's Run Blu-ray ReviewTaking of Pelham 1 2 3, The Blu-ray ReviewStar Trek Blu-ray ReviewUFC 100: Lesnar vs. Mir (2009) Blu-ray ReviewThe New York Ripper Blu-ray Review
Floating Wall: Mount TV on wall or wood?? Sonofabeesting Home Cinema DIY 6 09-07-2009 10:26 PM
Floating wall on partition wall???? dreamboat10 Home Cinema DIY 23 02-05-2008 11:18 PM
Floating wall ronaldo121 Home Cinema DIY 1 12-01-2008 12:02 PM
Help with a floating wall ronaldo121 Home Cinema DIY 5 04-01-2008 11:18 PM
Old 01-06-2008, 6:25 PM   #1 (permalink)
Floating wall for Rental Apartment
So i live in an apartment that I rent. I want to have a floating wall to hold my 42" panasonic tv (66 lbs) but I dont want to destroy the wall behind the floating wall. How can i create this Floating Wall but leave a minimal footprint on the wall behind. I already have an idea of how i want it to look but need some help on how to actually mount it to the wall, where to mount the bracket to, etc. My apartments walls are sheetrock and wood studs, no brick and I am thinking about using 1/2 in thick mdf. Any help will help. Thanx....
aesp533262 is offline   Reply With Quote
Old 01-06-2008, 9:38 PM   #2 (permalink)
Thanks: Gave 0, Got 3
Re: Floating wall for Rental Apartment
i would put a big thick piece of mdf or a couple of thick sheet's of hard wood and screw in 4 massive carriage bolts (enough to hold 66 lbs +) in to the studs from the corner.
Then you can build your false wall from that structure , bear in mind im no diy expert but this is just a suggestion.
p.s all you will have is 4 big holes to fill and paint over.
gokhan is offline   Reply With Quote
Old 01-06-2008, 11:19 PM   #3 (permalink)
Cant picture what you are trying to explain....can you elaborate.???
apartment, floating, rental, wall
