Go Back   AVForums.com > Home Cinema Construction and Configuration > Home Cinema DIY
Latest AVForums Movie Reviews
Gray Lady Down - Original Motion Picture Soundtrack CD ReviewUp Blu-ray ReviewLéon Blu-ray ReviewNear Dark Blu-ray ReviewLogan's Run Blu-ray Review
Taking of Pelham 1 2 3, The Blu-ray ReviewStar Trek Blu-ray ReviewUFC 100: Lesnar vs. Mir (2009) Blu-ray ReviewThe New York Ripper Blu-ray ReviewHeat Blu-ray Review
Concrete Ceiling - types of fittings? sapper Home Cinema DIY 1 20-02-2008 4:30 PM
Installing spotlights into a concrete ceiling jagdeepp Home Cinema DIY 7 12-12-2007 8:55 PM
Mounting to a concrete ceiling kcw CRT Projectors 2 17-08-2004 8:18 PM
Drilling a concrete ceiling Fonzerelli Home Cinema DIY 9 15-08-2004 12:50 PM
Ceiling void screen install PFM Home Cinema DIY 41 01-09-2003 4:12 PM
Old 25-05-2008, 4:11 PM   #1 (permalink)
Thanks: Gave 25, Got 25
HT install projector/screen in concrete ceiling?
Any recommendations on how to install a projector and a screen into a concrete ceiling? Will normall mounts work? Do I need special screws? And most important: will it hold - I wouldnt want 10lbs of projector falling on anybody's head....
Osamede is offline   Reply With Quote
Old 27-05-2008, 8:15 AM   #2 (permalink)
MarkP80's Avatar
Thanks: Gave 91, Got 76
Re: HT install projector/screen in concrete ceiling?
Concrete is a great material to get a fix into - no crumbling thermal blocks for you! I would recommmend expanding anchors, something like this - Screwfix. Not sure the exact size to recommend, but I think that looks about right - 8mm bolt, 75mm long fixing, for holding a heavy projector. Other opinions welcome!
Cheers,
MarkP
My Cinema and the Bar!
MarkP80 is online now   Reply With Quote
Old 27-05-2008, 5:23 PM   #3 (permalink)
Thanks for the info, Mark! Any other input appreciated.
Old 27-05-2008, 7:24 PM   #4 (permalink)
MasterYoda's Avatar
Thanks: Gave 12, Got 8
yeah, what mark says will hold and then some. I'd imagine 4 of them would hold it and you could probably hang off it too!!!
PS I don't suggest you hang off it and am not liable if you do and it all goes wrong
Master Yoda
MasterYoda is offline   Reply With Quote
ceiling, concrete, install, projector or screen
