| Re: Where to buy the wallplates that "cover up the hole"?
I've bought and used these brush faceplates in the past, and I think I'd be tempted to make my own next time. Looking at them, they look like standard network outlet plates, the type where the fitting you need clips into the standard aperture. Then, what appears to be simply door draught excluder has been glued on the back. So you might be able to pick up the brush material for trivial cost at a discount store for example.
As an alternative, I remember someone made a neat looking outlet using the round fitting from a halogen downlight. Looked very neat, they're cheap, and you can get them in chrome, brass, white etc.
MarkP
