Go Back   AVForums.com > Home Cinema Construction and Configuration > Home Cinema DIY
Latest AVForums Movie Reviews
Gray Lady Down - Original Motion Picture Soundtrack CD ReviewUp Blu-ray ReviewLéon Blu-ray ReviewNear Dark Blu-ray ReviewLogan's Run Blu-ray Review
Taking of Pelham 1 2 3, The Blu-ray ReviewStar Trek Blu-ray ReviewUFC 100: Lesnar vs. Mir (2009) Blu-ray ReviewThe New York Ripper Blu-ray ReviewHeat Blu-ray Review
upgrading sound sytem stephen75 PS3 8 16-04-2008 6:59 PM
Worth upgrading from Sony STR KS1000 to get hd sound ? SGH42 AV Amplifiers and Receivers 1 28-12-2007 7:25 AM
Advise on Upgrading to HD Sound Ulysses31 AV Amplifiers and Receivers 0 28-10-2007 12:32 PM
Upgrading my exisiting AV sound F G Evans AV Amplifiers and Receivers 2 07-01-2005 8:58 AM
Advice for upgrading sound stage please... sgecko Speakers 5 23-01-2003 5:50 PM
Old 25-05-2008, 8:49 AM   #1 (permalink)
Upgrading my Sound set-up?
Hi everyone,
Currently I have a 42" Samsung plasma, Sony DAV-DZ230 DVD home cinema and a PS3.
The DVD player is really naff and was a quick 'we need a new dvd player' purchase
Anyway, the PS3 is connected to the TV via HDMI, the DVD is connected to the TV via HDMI, I have no way of connecting the PS3 to the DVD home cinema so only get stereo sound from my PS3. There is no optical on the DVD home cinema so now im looking to get me a better system so I can get good sound from my PS3 and take advantage of the HD films.
Now im generally pretty good with gadgets and gizmos but when it comes to home cinema im pretty much useless
My budget is not massive so around the £300-350 mark would be good.
Can anyone sudgest something?
Nick
Also wouldnt mind being able to use my Samsung R700 laptop with the new amp as it has an HDMI output
USBulldog is offline   Reply With Quote
Old 25-05-2008, 9:19 AM   #2 (permalink)
Thanks: Gave 10, Got 57
Re: Upgrading my Sound set-up?
You might be better posting here:
http://www.avforums.com/forums/av-amplifiers-receivers/
Also if you only have Europe region 2 DVD's then maybe consider just using the PS3 for DVD playback, I read that it is quite good?
I would guess that if you change you amp you will also need to change your speakers, a lot of the all-in-one speakers are only suitable for that system, perhaps someone else can verify this.
As you have a PS3, you might want to get an amp that supports that HD sound formats available on HD Disks, look for amps that support LPCM (this is where the PS3 decodes the audio then sends to amp via hdmi).
Maybe consider the Denon 1908, Sony 920/820 or Onkyo 605/606.
Good luck and always get a demo/listen to the kit before you buy.
sp_harris is offline   Reply With Quote
Old 25-05-2008, 12:22 PM   #3 (permalink)
Ive posted it over there. Thanks for the heads up.
setup, sound, upgrading
