Go Back   AVForums.com > Home Cinema Construction and Configuration > Home Cinema DIY
Latest AVForums Movie Reviews
Gray Lady Down - Original Motion Picture Soundtrack CD ReviewUp Blu-ray ReviewLéon Blu-ray ReviewNear Dark Blu-ray ReviewLogan's Run Blu-ray Review
Taking of Pelham 1 2 3, The Blu-ray ReviewStar Trek Blu-ray ReviewUFC 100: Lesnar vs. Mir (2009) Blu-ray ReviewThe New York Ripper Blu-ray ReviewHeat Blu-ray Review
protecting neighbours from sub anolanbfg Subwoofers and Tactile Transducers 2 11-05-2008 6:07 AM
Protecting MacBook Lid asimm Mac Hardware, OS and Software 4 03-05-2008 9:11 AM
Protecting LCD TV with Perspex finst3r LCD Televisions 0 31-10-2007 7:24 PM
Source for furniture grade Wenge veneered MDF??? pcavelle AV Stands, Cabinets, Seating and Furniture 2 17-10-2007 8:29 PM
Veneered MDF vs laminated plasterboard? stevebez Room Acoustics, Audio and Video Calibration 3 14-09-2007 2:25 PM
Old 24-05-2008, 4:06 PM   #1 (permalink)
Thanks: Gave 50, Got 18
protecting oak veneered mdf
Hi all,
Just about getting to the stage where i need to think about what to put on my rack that i have built out of oak veneered mdf and oak edging.
I really haven't got a clue where to start with this one. I fancy a nice natural looking finish to the wood, should i use some sort of wax, or a varnish, i'm worried a varnish will look too shiny,
Look forward to hearing your suggestions.
Nathan
nathsea is offline   Reply With Quote
Old 24-05-2008, 6:43 PM   #2 (permalink)
Thanks: Gave 521, Got 448
Re: protecting oak veneered mdf
You could use Danish oil on the Oak, like I did with my Oak skirting (see my setup picture's in my signature), then give a very light coating of clear wax and buff with wire wool for a satin finish. Either that or use a satin varnish if you don't want a glossy finish. Definately get something on the bare wood or you'll get greasy marks from fingers over time that get engrained into the wood.
JVC HD350, ISCO II, 112" wide 2.35:1 Beamax, Lumagen HDQ, Sony 40W2000, Sony BDP-S350, Denon AVR-2808 plus Arcam P90/3, BK Monolith sub, BFD DEQ2496, PMC TB2M-C+, PMC DB1+, M&K K4 & K5.
Read the Projector FAQs
KelvinS1965 is offline   Reply With Quote
Old 24-05-2008, 8:22 PM   #3 (permalink)
Thanks: Gave 25, Got 108
I'd also recomend Danish oil - gives a nice satin finish without any additional work and is easy to spot re-finish if you get scratches or marks on the oak. I've used oil finishes on furniture, floors and stairs and have never regretted it.
neilball is offline   Reply With Quote
Old 24-05-2008, 8:37 PM   #4 (permalink)
thanks, looks like Danish Oil it is then..... is there any brand i should look out for, either good or bad
How do you apply it is it just rubbed on with a cloth?
Thanks again
Nathan
Old 24-05-2008, 10:56 PM   #5 (permalink)
Got mine in B&Q, can't remember the brand name, but I've got some in the garage I'll dig out tomorrow: Same as used by 'Miniholic' in his house building thread in the 'Member's Gallery' section for his doors, etc. Just rub it on with a cloth (does smell a bit so open the windows if possible) and work quickly to avoid uneven build up.
Can't beat natural materials: Just laying a sandstone patio today and we have an oiled Oak floor in the lounge that I layed last year. The variations in colours and textures is what makes it.
Old 25-05-2008, 10:31 AM   #6 (permalink)
Kelvin, Thanks for that, off to B&Q then to buy some.
Thanks again
Nathan
Old 24-09-2008, 9:46 PM   #7 (permalink)
Ronseal Satin Varnish or Matt if you want no sheen.
Any you guys ever come across oak veneer mdf that had been coated with Ronseal Diamond coat, a friend done it and it is covered in small black marks, 2-3mm long, under the varnish. A dirty brush?, Reaction to veneer glue? Old stock?
Any suggestions welcome.
BrettonWoods is offline   Reply With Quote
Old 11-11-2008, 4:54 PM   #8 (permalink)
Hi - yes. Same problem with American Black Walnut veneered mdf. I assumed reaction - not dirt etc. Looks a bit like small mold marks.
dghomes is offline   Reply With Quote
Old 13-11-2008, 4:33 PM   #9 (permalink)
Thanks: Gave 149, Got 27
Hi.
I don't know about american black walnut but with oak, the stains are almost certainly due to the wood being wiped over with plain water prior to being sealed.
Ronseal Diamond Coat isn't responsible. Most of my 2nd fix joinery is oak and the majority is coated up with satin Ronseal Diamond (mainly because of how hardwearing it is).
The only way to remove it is to lightly sand the oak veneer and then treat the staining with oxalic acid.
TBH if it's veneer this course of action may be either too much bother/ cause more damage.
Andy
diesel is offline   Reply With Quote
Old 13-11-2008, 5:52 PM   #10 (permalink)
Thanks: Gave 235, Got 213
I waxed the whole of my floor with Briwax.
Excellent stuff
Film JVC HD100,Carada BW variable masking,Denon 3800,Dacmagic, Oppo 983,Arcam AV8, P1, P7,Naim 135x4,Naim 250x2, Usher R1.5,Sonus Faber Extrema, Cremona, Elector amators, Gravis, 8033, Naim NACA5, Chord. Music Linn Sondek,Syrinx,Koetsu Red, Denon DCD3300, Croft, Tron 211, Living voice Airscout Horns
IWC Dopplel is offline   Reply With Quote
Old 14-11-2008, 12:05 AM   #11 (permalink)
The Prof.'s Avatar
Thanks: Gave 1, Got 39
I have just used a clear satin polyurethane ( water based ) on some oak timber..
Has no odour, very easy to apply and looks very classy..
Prof..
My Cinema
http://picasaweb.google.com/farmerNB/MyCinema#
The Prof. is offline   Reply With Quote
Old 14-11-2008, 11:14 AM   #12 (permalink)
Thanks: Gave 9, Got 21
"Any you guys ever come across oak veneer mdf that had been coated with Ronseal Diamond coat, a friend done it and it is covered in small black marks, 2-3mm long, under the varnish. A dirty brush?, Reaction to veneer glue? Old stock? "
He didn't use wire wool at all? Wire wool and oak generally don't get along too well together, and you can sometimes end up with what looks like beard trimmings under the varnish.
nacmacfeegle is offline   Reply With Quote
mdf, oak, protecting, veneered
