22-05-2008, 7:48 PM
#1 (permalink)
| | Senior Member
Thanks: Gave 453, Got 268 | help me mount my posters
Guys
I have x3 posters for my cinema room.I am concentrating on reducing reflections so i do not want to mount them with a frame and glass.
So I was thinking.............could'nt I just mount them on say thin ply board using some sort of paste?? (What sort do you think??)
This way i can then just drill through each corner, put caps over the screws and there we have it.
Any idea's chaps around my suggestion is appreciated.
Dave
__________________ MY HOME CINEMA MY KIT: Mits HC6000 1080PJ,Hitachi 42PD7200,92" Grandview Screen,Sony STR3200ES,SVS 5.0,Wharfedale SW150 Sub,
ToshHD E1,ToshHD EP-30, HD DVD Add On,Sky HD & Xbox 360. |
22-05-2008, 8:00 PM
#2 (permalink)
| | Veteran Member
Join Date: May 2007 Location: The Black Hole formally known as The Abyss!!
Thanks: Gave 603, Got 514 | Re: help me mount my posters Quote:
Dave | Hi Dave
you`ll like this mate, you can buy anti reflective glass, my mate used to be a picture framer and he did all ours with it.
Shop about mate and its not dear
Al |
23-05-2008, 8:02 AM
#4 (permalink)
| | Prominent Member
Join Date: Apr 2006 Location: You'd get your feet wet getting here
Thanks: Gave 198, Got 454 | Re: help me mount my posters
clcik on the link to my home cinema, pics in there of my movie posters cold mounted so you don't get ripples and also non reflective glass...it really works well
__________________ My Home Cinema Room My Gear: 108" Carada Screen, Panasonic AX100, Denon AVR3808, 7.1 B&W 6 Series speakers, Panny BD35(now Region free for Blu-ray!!), HTPC, XBOX 360, WII |
23-05-2008, 8:44 AM
#5 (permalink)
| | New Member
Thanks: Gave 6, Got 2 | Re: help me mount my posters
I had my cinema posters mounted on ply which was mounted on a 1" wood frame to add some depth. Paint the frame matt black (or something that suits the colour of the poster background, mine was black) and hang as you would a normal framed piccy.
You can use wallpaper paste or PVA glue to mount the poster to the board.
23-05-2008, 5:20 PM
#6 (permalink)
| | Senior Member
Thanks: Gave 453, Got 268 | Re: help me mount my posters
I want to mount it on the ply with no glass at all.The reflective glass still produces a sheen.I think I prefer the fact that the posters will be out in the open but do we think wall paper paste on ply will be ok??????
