17-05-2008, 2:30 PM
#1 (permalink)
| | Senior Member
Thanks: Gave 111, Got 262 | Wall Mounting 60" Pioneer
We're currently installing a 60" Pioneer onto (into) a false wall, and need a little bit of advice.
The panel will be mounted where the light is.
The KURO has a very thin (5mm) gloss depth we'd like to display:
Any suggestions on how to do this? It's going to be extremely difficult to get this bang on.
Are there any brackets that will allow the panel to be pulled away from the wall? I know they exist, but I've never seen any for 9-stone 60" panels.
Thanks in advance. |
17-05-2008, 5:34 PM
#2 (permalink)
| | Senior Member
Thanks: Gave 74, Got 160 | Re: Wall Mounting 60" Pioneer
when you say false wall , what exactly is the construction of the wall ?? , you are going to need some serious fixings to support that weight
Call me Paul  , Canon 450D , 18-55 IS and 70-300 IS |
17-05-2008, 6:51 PM
#3 (permalink)
| | Senior Member
Thanks: Gave 111, Got 262 | Re: Wall Mounting 60" Pioneer Quote:
Originally Posted by paulyoung666 when you say false wall , what exactly is the construction of the wall ?? , you are going to need some serious fixings to support that weight  | I think we've found a way now. I'll get some pics tomorrow of it all done (or a smashed/shattered 60" Pioneer on the floor).
It'd be good if anyone had any suggestions as well. |
18-05-2008, 6:09 AM
#4 (permalink)
| | Senior Member
i would offer suggestions , but i need to know the construction of the wall first
24-07-2008, 4:01 PM
#5 (permalink)
| | Prominent Member
Thanks: Gave 481, Got 254 | Re: Wall Mounting 60" Pioneer Quote:
Originally Posted by Kryptix We're currently installing a 60" Pioneer onto (into) a false wall, and need a little bit of advice......
.....Are there any brackets that will allow the panel to be pulled away from the wall? I know they exist, but I've never seen any for 9-stone 60" panels.
Thanks in advance.  | I'd be really interested in how you got on with this install Mr K
I'm going to be doing something very similar.
I'm getting a Pio 60". Just waiting to see if I prefer the KRP 600A or the 6090.
I also wanted a really good wall mount that will allow me to pull out the Pio and also angle it to the L or R if wanted.
After hours of research I've gone for the Future Automation PS60 Mount. It's a new model designed for 60"ers and can handle a load of 120 kg.
I've got that at home now and it is extremely well made and engineered - and it weighs a ton.
I have a timber framed house that is brick clad so I'm getting a builder out to tell me how I can re-inforce the wall sufficient to take all the weight. The fact that the TV can be pulled out adds tremendous stress as well as there is a downward leverage effect.
Anyway, how did you get on, and what mount did you go for in the end ? EDIT - Just noticed, and read, your THX Living Room DIY link.
Which shows in detail your progress. You changed your mind on the "pull out" bracket then ?
__________________ Pioneer KRP600A, Denon A1HDA, Panasonic BD35, Panasonic PX80, Panasonic DMR-E500, 2x Kef Ref 2.2's, Kef Ref 200c, 2x Kef Q2DS's, 2x Kef Q60's, SVS PB12-Ultra/2, Velodyne SMS-1. Nikon D300, 18-200mm, 17-55mm, TC-14E, Sigma 10-20mm, SB900. Flickr
01-08-2008, 9:33 AM
#6 (permalink)
| | Senior Member
We made out own in the end. It's very basic but does the job. It can be pushed in and out of the wall if we ever need to remove it. It's exactly what we were after. |
01-08-2008, 12:28 PM
#7 (permalink)
| | Prominent Member
Originally Posted by Kryptix We made out own in the end. It's very basic but does the job. It can be pushed in and out of the wall if we ever need to remove it. It's exactly what we were after.  | Smashing
__________________ Pioneer KRP600A, Denon A1HDA, Panasonic BD35, Panasonic PX80, Panasonic DMR-E500, 2x Kef Ref 2.2's, Kef Ref 200c, 2x Kef Q2DS's, 2x Kef Q60's, SVS PB12-Ultra/2, Velodyne SMS-1. Nikon D300, 18-200mm, 17-55mm, TC-14E, Sigma 10-20mm, SB900. Flickr |
