Go Back   AVForums.com > Home Cinema Construction and Configuration > Home Cinema DIY
Latest AVForums Movie Reviews
Terminator Salvation Blu-ray ReviewGray Lady Down - Original Motion Picture Soundtrack CD ReviewUp Blu-ray ReviewLéon Blu-ray ReviewNear Dark Blu-ray Review
Logan's Run Blu-ray ReviewTaking of Pelham 1 2 3, The Blu-ray ReviewStar Trek Blu-ray ReviewUFC 100: Lesnar vs. Mir (2009) Blu-ray ReviewThe New York Ripper Blu-ray Review
Fixing 32" LCD to solid Plasterboard Wall Stu2K8 Flat Screen TV Brackets and Mounts 4 09-02-2008 11:43 AM
Fixing LCR Bracket/Mount to Solid Wall seliamitabh Flat Screen TV Brackets and Mounts 4 01-02-2008 10:05 AM
Fixing Plasma bracket on soft wall chimpmagnet Flat Screen TV Brackets and Mounts 2 13-06-2005 10:43 AM
Best method of fixing to plasterboard / stud wall?? dealmaker Plasma Televisions 3 20-03-2004 8:04 AM
wall fixing a plasma markbigears Plasma Televisions 1 04-02-2004 7:09 PM
Old 16-05-2008, 12:06 PM   #1 (permalink)
Thanks: Gave 12, Got 8
Solid wall - best fixing method for 42" plasma
Hello All,
Just wanted some advice on mounting my bracket for 42" plasma. House is 1890's, wall is internal but not lathe and plaster. Seems to be solid - done a load of exploratory holes but not certain what its made of - best guess brick although it seems to have a solid metal piece running width of it (according to pipe/stud/electric detector...)
What do you think would be the best way to fix my bracket to the wall? Was originally going to mount it direct to wall but have noticed some people have fixed wood to wall first - is that just for Breeze block or is it best practice?
tojo is offline   Reply With Quote
Old 16-05-2008, 12:23 PM   #2 (permalink)
Thanks: Gave 603, Got 516
Re: Solid wall - best fixing method for 42" plasma
if its a solid wall and probably will be at that age just use rawl bolts or anchors as they art known as now, 4" or 100mm will be fine and use at least 4, 6 will be better.
cheers Al
See my selfbuild/basement cinema...Part 1 Big Al`s Big Basement Build Bonaza... Part 2
JVC HD350-Onkyo 905 MK SW150s MK SW95s MK SW85s MK MX5100 SF MONSTER 118" fixed screen-Harmony 1000-HTPC 8TB
albriscoe is offline   Reply With Quote
Old 16-05-2008, 1:04 PM   #3 (permalink)
wiz
Thanks: Gave 31, Got 21
Originally Posted by tojo View Post
Hello All,
I'd use screws, but you could try no nails!!!
...sorry I couldn't resist, it is Friday!!
Panasonic TH-37PX7B, Onkyo 875 ,
Sony BDP-S350, Sky+
Front Mission 773, Center Canton CD50, Rear Mission 70DS
wiz is offline   Reply With Quote
Old 19-05-2008, 12:24 PM   #4 (permalink)
Cheers All!
plasma
