Go Back   AVForums.com > Home Cinema Construction and Configuration > Home Cinema DIY
Latest AVForums Movie Reviews
Up Blu-ray ReviewLéon Blu-ray ReviewNear Dark Blu-ray ReviewLogan's Run Blu-ray ReviewTaking of Pelham 1 2 3, The Blu-ray Review
Star Trek Blu-ray ReviewUFC 100: Lesnar vs. Mir (2009) Blu-ray ReviewThe New York Ripper Blu-ray ReviewHeat Blu-ray ReviewMoon Blu-ray Review
TV above Fireplace. bigjoe7 LCD Televisions 2 15-01-2008 3:20 PM
LCD above Fireplace frofan Custom Installations and Installers 0 21-09-2007 8:02 PM
LCD over fireplace??? snowflake LCD Televisions 4 07-08-2006 11:33 AM
LCD above a fireplace NinjaKi11a LCD Televisions 4 04-04-2005 3:11 PM
How far away should the fireplace be dlptv4me Projectors 3 22-04-2004 1:36 PM
Old 13-05-2008, 10:35 AM   #1 (permalink)
Thanks: Gave 2, Got 7
Fireplace thoughts
Here's the scenario. I currently have a chimney breast with a gas flue in it and a 'feature electric' fireplace (read illuminated fan heater!). I would like to rip it out, board up the hole and mount my 42" panny on it, couple of units below (similar to Groove's) with my components in it and cabling hidden in the wall.
We don't use the fireplace for heat - prefer the modern convinience of a timed, thermostatically controlled radiator, unfortunately SWMBO likes the fireplace and wants to keep it, but acknowledges that the TV mounted above would be too high. Aparently it makes a good focal point - personally I think a 42" full HD panny makes a great focal point and a fireplace screensaver on a PC aparently won't cut it.
Does anyone have any thoughts on how we can meet in the middle somewhere?
Many Thanks
fredd500 is offline   Reply With Quote
Old 13-05-2008, 10:49 AM   #2 (permalink)
vex
Assured Advertiser
Thanks: Gave 9, Got 181
Re: Fireplace thoughts
Depending on the room layout, we mounted ours to the side on a pull out and twist bracket.
Day to Day it is out facing into the room, for parties and visitors it get pushed back and 'hidden' round the corner of the fireplace.
V.
Be careful out there forumites - 89% of statistics are made up.
vex is offline   Reply With Quote
Old 13-05-2008, 10:52 AM   #3 (permalink)
snellfish's Avatar
Thanks: Gave 37, Got 60
V.
any pics of this setup?
We Are Evil
snellfish is offline   Reply With Quote
Old 13-05-2008, 10:58 AM   #4 (permalink)
vex
Assured Advertiser
It is only (currently) on a 32" but I will try to get some photos sorted for you.
V.
Old 13-05-2008, 12:02 PM   #5 (permalink)
Thanks: Gave 2, Got 14
Buy or make a DVD of a log fire and show it on your screen - Dimplex do an electric fire which is just a big TFT screen, comes with a memory card with different fire scenes on (honest - http://www.dimplex.co.uk/products/fi..._art/index.htm)
GeoffWork is offline   Reply With Quote
fireplace, thoughts
