| Re: Can a false or "floating" wall be soundproofed?
British Gypsum make various soundblock boards that you can stick on the wall, but if you then screw/bolt a floating wall you would have to pass through the soundblock board to the wall behind to achieve a firm fixing
This would diminish a lot of the gains you have made
You could build a stooling wall in front off the existing wall and insulate that and then fix a floating wall on to that, this would be a better solution for soundproofing
__________________ Steve
kit:-Panasonic TH-50PF10,Lumagen Radiance XD,Onkyo PR-SC886 ,Nad M25,Tosh SD9500 ,Tosh EP35,Samsung BD-P1500,SKYHD,Xbox 360,PS3,M&K THX S150's/SS150's,SVS pb12-plus/2 subwoofer
