Go Back   AVForums.com > Home Cinema Construction and Configuration > Home Cinema DIY
Latest AVForums Movie Reviews
Up Blu-ray ReviewLéon Blu-ray ReviewNear Dark Blu-ray ReviewLogan's Run Blu-ray ReviewTaking of Pelham 1 2 3, The Blu-ray Review
Star Trek Blu-ray ReviewUFC 100: Lesnar vs. Mir (2009) Blu-ray ReviewThe New York Ripper Blu-ray ReviewHeat Blu-ray ReviewMoon Blu-ray Review
Sound insulation for Ceiling speakers PannyAdams Speakers 0 10-11-2006 9:23 PM
sound insulation johnone Home Cinema DIY 0 02-04-2006 4:03 PM
quick sound insulation question bockster Home Cinema DIY 5 29-08-2005 10:05 PM
Cheap sound Insulation? The_Mole Room Acoustics, Audio and Video Calibration 3 24-08-2005 7:28 PM
Exiting Celing.. Sound Insulation.. HELP dynamix Room Acoustics, Audio and Video Calibration 6 24-05-2005 11:39 AM
Old 02-05-2008, 3:35 PM   #1 (permalink)
Thanks: Gave 8, Got 3
Sound insulation IN a chimney
I'm not sure if this is quite the right place for this thread, but as there are many experienced DIY'ers here, its a good place to start.
We have a bot of a problem in our 1930's house - When our neighbours have their TV on in the downstairs lounge, the sound echos into our bedroom via the chimney.
In our house the lounge is directly below the bedroom and the chimney breast passes through the bedroom on its way to the chimney. Sadly we cant take it out as it is shared with next door and it would be a pretty major structural job.
We dont use the fireplace in the lounge and it has an electric Dimplex fire fitted purely for cosmetic purposes.
Next door dont use their fire either.
When we're in our bedroom, you can hear the noise from their TV clearly coming from the chimney breast. Listening against the other walls and floor, you cant really hear much but as soon as you listen against anywher eon the chimney breast you can hear it.
From this I assume the sound from their TV is travelling up their chimney and somehow finding its way into our chimney.
Does anyone have any ideas on how to prevent this?
Goochie is offline   Reply With Quote
Old 02-05-2008, 3:48 PM   #2 (permalink)
Thanks: Gave 24, Got 6
Re: Sound insulation IN a chimney
the noise you are getting is airbourne noise not impact noise..the beast way to deal with airbourne noise is to "absorb" it..if your not using the the chimney at all try packing it with a roll of Rockwool
http://www.rockwool.co.uk/graphics/R...heets/Roll.pdf
dazzarooney is offline   Reply With Quote
chimney, insulation, sound
