25-04-2008, 7:27 PM
#1 (permalink)
Thanks: Gave 28, Got 8
Source for floating shelves?
Can anyone recommend a source to get floating shelves, ideally white?
I've seen the ones that Ikea sell but they are a bit flimsy.
Lance
25-04-2008, 7:46 PM
#2 (permalink)
Thanks: Gave 158, Got 177
Re: Source for floating shelves?
check out frequently asked diy questions at the op of the page! Theres a very good thread about how to build your own floating shelfs
Optoma HD800X / 84" Screen / Sony Bravia KLV-V40A / Sony HT-IS100 / SkyHD / Harmony One / PS3 / Xbox 360 / Wii / Vaio FZ21E Samsung LE37A656A Black Rose (bedroom) TV.
25-04-2008, 7:50 PM
#3 (permalink)
Thanks for you reply.
I saw the thread by Paul D, but I don't really want to chase out my walls, and ideally wanted to buy something off the shelf if you pardon the pun
Regards
Lance
26-04-2008, 7:23 PM
#4 (permalink)
Thanks: Gave 3, Got 10
Not white, but www.dwell.co.uk have some floating shelves. We got some of the Walnut ones and they are very solid. I've seen some in Homebase as well but probably just as flimsy as Ikea.
26-04-2008, 8:15 PM
#5 (permalink)
Thanks: Gave 16, Got 105
Dwell do them in high gloss white, 3 sizes. I have a couple of them. http://dwell.co.uk/product.php?prod=102871
John.
29-04-2008, 7:26 AM
#6 (permalink)
Thanks for the replies
I'll have a look at Dwell.
29-04-2008, 1:17 PM
#7 (permalink)
Thanks: Gave 1, Got 0
I don't know if there is an Ikea near you, but check out the Lack Range if there is.
http://www.ikea.com/gb/en/catalog/products/20103752
I bought them in white and they look good.
MJ
29-04-2008, 9:52 PM
#8 (permalink)
Originally Posted by mjsmyth
Thanks but I don't think the Ikea ones are solid enough for what I want to put on them
01-05-2008, 1:15 PM
#9 (permalink)
Thanks: Gave 37, Got 36
B&Q & homebase also do them.... a lil on the expensive side though
01-05-2008, 1:15 PM
#10 (permalink)
3 sizes in homebase... bought 2 mid size ones for £15 each a month ago
11-07-2008, 3:39 PM
#11 (permalink)
Thanks: Gave 5, Got 1
can you fit a v+ cable box or Sky box on them ?
11-07-2008, 9:33 PM
#12 (permalink)
Thanks: Gave 5, Got 11
my local B and Q are now selling floating shelves maybe your local branch has them as well , depth however isnt massive but its stil worth a look maybe
Whats life without a gadget
13-07-2008, 12:58 AM
#13 (permalink)
Thanks: Gave 12, Got 14
I'd take the Ikea ones over the Homebase anytime - I installed the former very easily, and it is very stable. I recently bought several of the latter, and was appalled to find the veneer lifting from the edges, and found the mounting rods to be far less sturdy than the Ikea ones - overall not a good buy, even with the 'buy 2 get 1 free' offer. In fact I intend to send mine back :]
KatTV
Sony KDL-46W4500 / Yamaha DSP-AX 763 / Monitor Audio Radius 270 fronts / 225 centre / 90 surrounds / BDP-S350 / RDR-HX860s / Toshiba HD-EP35 / Humax FoxSat HD / Apple TV + EyeTV 250 + Mac / Wii
04-02-2009, 9:26 PM
#14 (permalink)
Thanks: Gave 1, Got 1
Hi got some white one's off the shelf (  ) from here
Chunky floating shelf price calculator buy online
have to fit your self but not to hard, fit my sky box and PS3 just right even put a cable cut out in them for me
the spandangly
04-02-2009, 10:44 PM
#15 (permalink)
Thanks: Gave 60, Got 42
Originally Posted by spandangly
OMG, they're perfect!  I want some nice looking shelves for my Blu-rays and all other floating shelves I've seen are too deep for my liking. I can now have 150mm deep shelves just they way I like 'em.
