Go Back   AVForums.com > Home Cinema Construction and Configuration > Home Cinema DIY
Latest AVForums Movie Reviews
Terminator Salvation Blu-ray ReviewGray Lady Down - Original Motion Picture Soundtrack CD ReviewUp Blu-ray ReviewLéon Blu-ray ReviewNear Dark Blu-ray Review
Logan's Run Blu-ray ReviewTaking of Pelham 1 2 3, The Blu-ray ReviewStar Trek Blu-ray ReviewUFC 100: Lesnar vs. Mir (2009) Blu-ray ReviewThe New York Ripper Blu-ray Review
Floating Wall: Mount TV on wall or wood?? Sonofabeesting Home Cinema DIY 6 09-07-2009 10:26 PM
Why a floating wall ? Cynar Home Cinema DIY 14 05-05-2008 11:40 AM
Floating wall on partition wall???? dreamboat10 Home Cinema DIY 23 02-05-2008 11:18 PM
Floating wall ronaldo121 Home Cinema DIY 1 12-01-2008 12:02 PM
Old 24-04-2008, 12:55 PM   #1 (permalink)
Thanks: Gave 0, Got 16
Another floating wall, around a fireplace
Hi guys, after all the great floating walls I’ve seen on the forums I thought I’d take the plunge.
So here are a few pictures of my floating wall above our fireplace.
Please let me know what you think and if you have a questions.
hatchn is offline   Reply With Quote
Old 24-04-2008, 1:55 PM   #2 (permalink)
Thanks: Gave 15, Got 32
Re: Another floating wall, around a fireplace
Nice Boomerang.
I prefer the floating wall in picture 4 before you extend it down past the sides of the fireplace. It looks more in proportion that way. Do the lights shine around the inside by the fireplace, or just the outside of the floating wall.
Da_Rude_Baboon is offline   Reply With Quote
Old 24-04-2008, 2:03 PM   #3 (permalink)
At the moment the lights are just around the edge but I think I'm going to whack them in around the fireplace too. I've got a load of rope light left as that was the initial plan but "her indoors" was not convinced.................
Old 25-04-2008, 2:49 PM   #4 (permalink)
Looks good....what speakers have you got there ?
mudu is offline   Reply With Quote
Old 29-04-2008, 4:21 PM   #5 (permalink)
They are Celestion AVS501 from Hyperfi in Barking (Essex) or via the web at
http://www.hyperfi.co.uk/default.asp...ion_avs501_new
I managed to get 5 speakers for £199.00 on Ebay, can't fault the sound or build quality.
Just make sure you pair them with a decent Sub. I have mine paired with a Miller & Kreisel KX-10SF and they sound great.
Old 29-04-2008, 4:54 PM   #6 (permalink)
I have updated post to embed the pictures properly.
Please see original 1st post.
Old 02-05-2008, 7:03 PM   #7 (permalink)
groove's Avatar
Thanks: Gave 93, Got 150
I bet you're well pleased with that hatcn....looks great mate , really good job.
groove is offline   Reply With Quote
Old 18-05-2008, 4:27 PM   #8 (permalink)
hi m8 looks great thats just what i want to do. can you tell me did you use mdf. and what size wood did you use for the frame work. looks fantastic that
john1509 is offline   Reply With Quote
Old 22-05-2008, 12:25 PM   #9 (permalink)
Thanks: Gave 7, Got 3
such a womans question but.... we are doing something similar inc replacing current fireplace and showed the missus the pic and she liked the fireplace!
Where is it from? :D
jimmyca69 is offline   Reply With Quote
Old 28-05-2008, 3:08 PM   #10 (permalink)
Thanks: Gave 9, Got 37
Originally Posted by Da_Rude_Baboon View Post
Nice Boomerang.
does look nice just then without the legs types extension but im guessing the whole point is to be able to get the wires down to the cabinet without chopping out anything in the wall or using trunking down the wall so there necessary
I have been looking at this over my fireplace so glad i stumbled across this thread and getting the wall made up just like in pic 4 and thought about making these kinds of legs down each side but looks like i will have to chop out of the wall and plaster etc to get it all hidden
@ hatchn looks great mate sinking in the TV and speakers works really well
Hi-Def is offline   Reply With Quote
Old 28-05-2008, 3:44 PM   #11 (permalink)
snellfish's Avatar
Thanks: Gave 37, Got 60
i think it would look better if the false wall was painted the same colour as the wall behind. imo it would look more subtle.
We Are Evil
snellfish is offline   Reply With Quote
Old 30-05-2008, 8:13 PM   #12 (permalink)
Thanks: Gave 113, Got 100
These speakers use to retail for around £1250 for 5 without a sub so they are a super bargain at the price - excellent build quality and they blend in great with a flatscreen set up - how well do you rate the sound?
Suave!
Suave is offline   Reply With Quote
fireplace, floating, wall
