Free electronics advice and information
3.5 million visitors each month
Go Back   AVForums.com > Home Cinema Construction and Configuration > Home Cinema DIY
Latest AVForums Movie Reviews
Sherlock Holmes Blu-ray ReviewClash Of The Titans - Original Motion Picture Soundtrack CD ReviewZombieland Blu-ray ReviewLast King of Scotland, The Blu-ray ReviewAfrican Queen, The Blu-ray Review
Cirque du Freak: The Vampire's Assistant Blu-ray ReviewToy Story Blu-ray ReviewClash Of The Titans Blu-ray ReviewVengeance Blu-ray ReviewHellboy Animated: Sword Of Storms/Blood and Iron Blu-ray Review
Thread Thread Starter Forum Replies Last Post
..... in my pants.... Mrs AutomanUK General Chat 256 10-07-2006 6:29 AM
Region 1 Dvd: Why Uk R2 Is Pants!! howard444 Movie Suppliers and Technology 34 23-06-2005 3:34 PM
argos...pants is it then?? parrots Plasma TVs 1 27-12-2004 3:01 PM
ProLogic II .. PANTS !! Zog AV Amplifiers and Receivers 48 20-04-2002 3:53 PM
How pants is this? Family Guy Movies and The Cinema 11 16-03-2002 12:44 PM
Old 27-02-2008, 4:38 PM   #1 (permalink)
Thanks: Gave 72, Got 64
My install looks pants! Help please
Hi guys.
Below is a pic of my install. On the right hand side you can just see the entrance into my kitchen (the two rooms are semi open plan). There is a pic of the kitchen aswell (if that helps?)
In the room it self there is a black leather sofa.
Now the problem is the install looks soooooooooo boring compared to so many I've seen on here.
Can anybody help with some ideas to add some wow factor? I'm happy to do anything ie add cabinets/shelves, repaint the TV wall another colour etc an AV cabinet with door needs to stay though as I have small kids with sticky fingers.
The only idea I already have is to add led lights behind the TV and beneath the AV cabinet (after raising it a few inches).
All ideas welcomed
In this photo the double doors the seem to overlook the garden are gone and thats where the TV room has now been built and so is semi open plan
indus is offline   Reply With Quote
Old 27-02-2008, 5:01 PM   #2 (permalink)
Thanks: Gave 19, Got 51
Re: My install looks pants! Help please
I think the biggest and easiest improvement would be to paint the TV wall. I personally think chocolate suede effect works very well for this purpose.
Samsung PS50Q96HD / Sony STR-DA5200ES / Toshiba HD-E1 / Panasonic DMP-BD35 (B) / PS3 Slim (B) / PS3 (A) / Sky HD (1TB) / Kef 2xQ7, Q9c, 4xQ2ds, PSW2500
EddyHorn is offline   Reply With Quote
Old 27-02-2008, 5:10 PM   #3 (permalink)
t1m103's Avatar
Thanks: Gave 131, Got 155
nice looking kitchen btw.
t1m103 is offline   Reply With Quote
Old 27-02-2008, 5:15 PM   #4 (permalink)
Thanks: Gave 69, Got 182
I'd agree, repaint the wall, the LED lights is a nice idea too. I think your speakers would be helped by "framing" them, and totally losing the cables (pet hate)
regards
Brian
bsuttie is offline   Reply With Quote
Old 27-02-2008, 5:42 PM   #5 (permalink)
Thanks: Gave 1, Got 14
Not really much you could do with that space with those 2 rads either side ! I've seen a floating wall that a few people have done in rooms in other threads on here which seem to give off a nice effect....you can then backlight the floating wall rather than your TV ! Not sure if its possible to have it across the whole wall with the rads still behind it...but if not then you could do it in the space between the rads and have your floating wall a different colour to the rest of the wall with some downlighters above it just for added effect !
This will be ideal for hiding your wires behind as well. Its something I'm seriously considering for when I hopefully move house soon as the missus has said I can have to garage to do with what I want....so of course having seen some of the self builds etc on here I've decided on a home entertainment/chill out room....can't wait to get started !
Is it not possible to move the rads to another wall and just make do with the one that way giving you a whole wall to play with ?
Setup: Samsung LE40F86BDX, PS3, Sky+SD, Pioneer NSDV-55 Surround System
cronemeister is offline   Reply With Quote
Old 27-02-2008, 5:48 PM   #6 (permalink)
Thanks: Gave 5, Got 166
regards
Brian
My Kef TDM's give a me the same effect
Steve
kit:-Panasonic TH-50PF10,Lumagen Radiance XD,Onkyo PR-SC886 ,Nad M25,Tosh SD9500 ,Tosh EP35,Samsung BD-P1500,SKYHD,Xbox 360,PS3,M&K THX S150's/SS150's,SVS pb12-plus/2 subwoofer
jolly is offline   Reply With Quote
Old 27-02-2008, 6:10 PM   #7 (permalink)
Alun's Avatar
Thanks: Gave 303, Got 259
how about not painting the entire wall, and just shuffling your speakers a bit so it doesnt look as cluttered.
maybe a couple of shelves either side for dvd's?
tried to put some shelves up, but pretty limited as to what I can do at work.
Cheers,
Alun
Sometimes I feel like throwing my hands up in the air...
My Flickr
Alun is offline   Reply With Quote
Old 27-02-2008, 6:36 PM   #8 (permalink)
Thanks: Gave 3, Got 11
TBH....i aint a lover of speakers so close to the sides of the tv...
I would get a little 3 foot corner unit with glass door for AV gear(put it under the dimmer) i know u would cover a little of the rad .
Move the left and right speakers maybe put them right up into the left and right corners of room ,then maybe get a floor stand for the center speaker...or frame it into the wall (similar to where it is now).
More ideas you get the better
Good luck with it though.
Your kitchen is FAB !!! love it )
chrispeters is offline   Reply With Quote
Old 27-02-2008, 7:07 PM   #9 (permalink)
marksimonwright's Avatar
Thanks: Gave 236, Got 114
Love the Kitchen
I would go for two floating shelves from Ikease and, sit the speakers underneath and, two wall lights.
Attached is a picture of my lounge (Taken from my remote control).
It will give you a sense of how your set-up would look with wall lights, lights behind the tv and putting your speakers underneath.
I'm not saying the my set up is right for you, it's a personal choice, just giving you a flavour of how it could like
Have to say it again, thats is a great kitchen.
marksimonwright is online now   Reply With Quote
Old 27-02-2008, 7:14 PM   #10 (permalink)
wrong attachement - see this one
http://www.avforums.com/forums/attac...0&d=1202674922
Old 27-02-2008, 9:12 PM   #11 (permalink)
Thanks: Gave 20, Got 20
completely off topic ! That is a sweeet looking kitchen Indus, love those cabinets, and that unusal cooker hob, where's that from?
And is that roti on the side :D
ballyg is offline   Reply With Quote
Old 27-02-2008, 9:23 PM   #12 (permalink)
Possibly hiding all you eqipment (cupboard, underneath stairs) and getting rid of the AV stand may help with the type of look you might want to achieve.
Mark
Old 27-02-2008, 11:00 PM   #13 (permalink)
Mark..i love wot u done with your living room...it looks excellent !!! wow
Old 28-02-2008, 9:04 AM   #14 (permalink)
Franco50's Avatar
Thanks: Gave 41, Got 39
I'm another one who is going to rave about your kitchen and offer absolutely no help to your AV problem - sorry.
Franco50 is offline   Reply With Quote
Old 28-02-2008, 9:10 AM   #15 (permalink)
dclayton's Avatar
Thanks: Gave 53, Got 41
I think something like this would work really well on that wall:
A floating in-wall system like this would enable you to keep the radiators where they are. Though I think you'd have to upgrade to larger speakers to get the best effect.
See the full thread by stevelup here
dclayton is offline   Reply With Quote
install, pants
Copyright © 2000-2010 M2N E. & O. E.
