Go Back   AVForums.com > Home Cinema Construction and Configuration > Home Cinema DIY
Latest AVForums Movie Reviews
Terminator Salvation Blu-ray ReviewGray Lady Down - Original Motion Picture Soundtrack CD ReviewUp Blu-ray ReviewLéon Blu-ray ReviewNear Dark Blu-ray Review
Logan's Run Blu-ray ReviewTaking of Pelham 1 2 3, The Blu-ray ReviewStar Trek Blu-ray ReviewUFC 100: Lesnar vs. Mir (2009) Blu-ray ReviewThe New York Ripper Blu-ray Review
Monster HTS1000 Home Theatre PowerCentre or Belkin PureAV Isolator Home Theatre SP mattj222 Interconnects, Speaker Cables and Switches 4 08-03-2008 3:57 PM
New loft project Roguey Home Cinema DIY 27 19-02-2005 8:36 PM
help with new loft project andya Home Cinema DIY 12 04-07-2004 3:32 PM
Old 12-02-2008, 7:35 PM   #1 (permalink)
Thanks: Gave 4, Got 0
My Loft Theatre Project
Hi there! guess you know that i am making a theatre in my loft. Well, i thought i would just keep you lot updated, these updates could be a little slower than they should be because the builder refuses to come, but anyway here we go.
Day 5 (because i wasnt taking pictures until then)
Just a look around the loft, he was putting in the plaster board today.
This is a tank for our boiler, we cant take it out because our central heating wont work so we have to move it somewhere
This is the wall where my tv and things are going to go
Day 7
Now the loft is cleaned up a bit and a bit of the wiring is done, next step is the plastering. Also the water tank has been moved to the corner, and he is going to put chipboard/floorboard whatever on top of the gap.
The bottom thing is for a chrome double dimmer, the gap in the left side is for a wall light. The other one is going to the ceiling light
This is where the ceiling light is going to go, it is going to be a standard 150watt indacandescent thing bulb, you know the big round ones.
Well i will keep updating, but throughout the thread, this post is long enough as it is.
theatre-aholic is offline   Reply With Quote
Old 14-02-2008, 9:48 AM   #2 (permalink)
Thanks: Gave 21, Got 8
Re: My Loft Theatre Project
keep the pics coming
connorjordan is offline   Reply With Quote
Old 11-03-2008, 10:58 PM   #3 (permalink)
mhuk05's Avatar
Thanks: Gave 31, Got 126
Are those electrical cables behind the metal trunking in the 2nd to last photo? Electrical cables should run vertically- makes it easier not to drill through them when it's plastered over.
mhuk05 is offline   Reply With Quote
Old 11-03-2008, 11:11 PM   #4 (permalink)
Assured Advertiser
dj-dulux's Avatar
Thanks: Gave 8, Got 101
I'd remove the metal capping picture, just in case your building inspector is an AV fan. Who is doing the wiring?
Dupe....
105dB at 3m with 2W... without line arrays or compression drivers
Life's better when it's wired! - Wired Life
Proud to be an AVForums sponsor and assured advertiser
dj-dulux is offline   Reply With Quote
Old 18-03-2008, 6:31 PM   #5 (permalink)
Thanks: Gave 0, Got 5
Looking good.
What equipment you putting up there?
Whats the dimensions of the room?
chrish16 is offline   Reply With Quote
Old 19-03-2008, 7:46 PM   #6 (permalink)
Thanks: Gave 14, Got 30
Dupe....
You should do more than just remove the capping picture; you should get a competent spark to sort that out. The cables are not positioned in the prescribed zones and are not mechanically protected (capping doesn’t count).
Please don’t take offence as we are only trying to point you in the right direction.
Regards,
ZippyCat
ZippyCat is offline   Reply With Quote
loft, project, theatre
