07-02-2008, 2:18 PM
#1 (permalink)
Thanks: Gave 202, Got 153
Gloss on MDF
In process of making new equipment stand - cut all pieces to fit and glossed the legs leaving the two big peices of MDF for another time.
The other half thinking was helping has come and glossed both pieces for me perfectly - nice clean tidy finish. However ...................
No undercoat was put on. Now how will this effect things ? Is it ruined ? Will it ever dry ? Can it be fixed
07-02-2008, 3:59 PM
#2 (permalink)
Thanks: Gave 167, Got 74
Re: Gloss on MDF
I glossed an MDF door at my parents place without undercoating, and the paint gradually got absorbed by the MDF and eventually started to peel.
07-02-2008, 4:01 PM
#3 (permalink)
Re: Gloss on MDF
Yeah that seems to be whats happening here
Looks like may be ruined - not sure if another coat would help
07-02-2008, 4:27 PM
#4 (permalink)
Re: Gloss on MDF
I doubt it, tbh. You live and learn...
07-02-2008, 5:00 PM
#5 (permalink)
Re: Gloss on MDF
Guess I could try letting it dry - rubbing down and then undercoating first
07-02-2008, 5:08 PM
#6 (permalink)
Re: Gloss on MDF
Yeah, I guess that might work
07-02-2008, 5:14 PM
#7 (permalink)
Thanks: Gave 5, Got 166
Re: Gloss on MDF
I think that will work, the cut edges of the mdf need special treatment
Steve
kit:-Panasonic TH-50PF10,Lumagen Radiance XD,Onkyo PR-SC886 ,Nad M25,Tosh SD9500 ,Tosh EP35,Samsung BD-P1500,SKYHD,Xbox 360,PS3,M&K THX S150's/SS150's,SVS pb12-plus/2 subwoofer
07-02-2008, 7:26 PM
#8 (permalink)
Re: Gloss on MDF
Seems as if one side at least may be ok - forcebly run hand down it and its smooth and dry with no signs of peeling - the other side though is a mess
08-02-2008, 9:06 AM
#9 (permalink)
Thanks: Gave 44, Got 16
Re: Gloss on MDF
any photos? I was tempted to gloss paint mdf but didnt think you could get a smooth finish. was it just painted on?
Also read you can get the bits of mdf lacquered
08-02-2008, 9:13 AM
#10 (permalink)
Thanks: Gave 97, Got 96
Re: Gloss on MDF
Bit late for dunkle, but for MDF I would recommend you always paint with special MDF primer first. MDF is very absorbent, especially on the cut edges, and you can easily make it swell. The proper primer seals this, ready for you to paint as normal. You can buy it in B&Q.
Cheers,
MarkP
08-02-2008, 10:25 AM
#11 (permalink)
Re: Gloss on MDF
Cheers,
MarkP
LOL
I have a big pot of it already - just a shame was beaten to it
Going to try sanding it all down and starting again
08-02-2008, 2:36 PM
#12 (permalink)
Thanks: Gave 18, Got 41
Re: Gloss on MDF
Can you not seal MDF with a PVA and water mix?
08-02-2008, 3:15 PM
#13 (permalink)
Re: Gloss on MDF
I believe you can
Steve
