07-02-2008, 2:26 AM
#1 (permalink)
| | Member
Thanks: Gave 13, Got 12 | my attempt at bedroom home cinema
Hi all,
Just thought would share with you all my attempt at going to create my bedroom home cinema setup. I have included a couple of pictures of before and a mock up of how it should look, should being the word.
Kit list of all its to hold
panasonic th50px60
onkyo 805
speakers at moment tannoy efx but they will change
xbox 360
ps3
cable box
hd dvd and a dvd recorder
first picture is how my old screen looked now got a new electric remote one to be also fitted
second picture is my first surrpund kit and speakers that was replaced with the efx and pioneer 1016 which has now been replaced with a onkyo 805
And the last picture is how im hoping the new build will look, with the plasma inserted into the raised wall. Along with the speakers and the av storage under it which I will be making. there will be blue led lights going on the back shelf pointing up and some under the storage unit and 6 behind the plasma.
Under the av storage section the bottom part of wall and skirting will be hinged so can be lifted to get full access to the plugs and chaning cables if needed
Any views ideas most welcomed
Ewan
07-02-2008, 6:40 AM
#2 (permalink)
| | Member
Thanks: Gave 28, Got 21 | Re: my attempt at bedroom home cinema
nice swords. I've always wanted some of those in my room. Just getting them through customs is the difficult part.
07-02-2008, 11:03 PM
#3 (permalink)
| | Member
Thanks: Gave 13, Got 12 | Re: my attempt at bedroom home cinema
Just thought would post an update incase anyone was intrested.
Put the back bracing timber up and half sheet plasterboard before the mount the plasma bracket is put on. aswell as part the frame to frame around where the tv will be mounted.
Last picture is after taking the coving down and my previous fitted leds, so could work out hights and placement for the projector screen tomorrow.
Thanks the swords were bought here 2 years ago, some cataloge clearing sale for £60.
Hope its not to boring for everyone
Ewan
07-02-2008, 11:10 PM
#4 (permalink)
| | Veteran Member
Thanks: Gave 463, Got 575 | Re: my attempt at bedroom home cinema
Looking good so far Ewan  keep us updated m8
Tony
25-02-2008, 12:01 AM
#5 (permalink)
| | Member
Hi all been a tad busy thought that would update this on how its going and whats been happing. Well slow progress at first due to being undecided about speakers in the end went with quad lites even managed to find them in stock in black.
As to whats been happing well here goes, after the hold up with the speakers once they were bought it was all go once had the sizes and could finish building the top section, which is were the tv and speakers will be housed. Also added a second double plug point aswell as the blue led lights. The first coat of paint was applyed after the plaster dried today, talk about home build I forgot how tiresome skimming with plaster is. The projector screen was also boxed in and plastered fits perfectly.
The picture of the back wall lit up showing the white looks like 2 blocks on the shelf its actualy 2 holes had to cun to get to the screws under the plasma mount to stop it coming away from the wall when tilted, will use them to pass the connection cables through aswell.
included pictures are
projector screen boxed in
some of the frame build
the tv wall bracket
A dry fit so to speak with the tv in place
shiney black quads,
and the wall lit up with the first coat
Now that the top section is about done tv will be on the wall tomorrow night, and bottom section that will hold all the av eqquipment will be started. Have realised that my projector will have to be brought forward due to throw distance so got to redo the ceiling aswell now.
Have decided to cut out a section of wall to turn into flush wall dvd storage.
Still to buy 10m hdmi cable, and 1:2 hdmi splitter anyone know where to get best prices on either?
Hope this all makes sence and please feel free to make any comments or to give pointers.
Ewan
Reason: point
25-02-2008, 8:53 AM
#6 (permalink)
| | Member
Thanks: Gave 92, Got 76 | Re: my attempt at bedroom home cinema
Looks really nice Ewan, well done mate!
MarkP
25-02-2008, 1:07 PM
#7 (permalink)
| | Member
Thanks: Gave 12, Got 8 | Re: my attempt at bedroom home cinema
Looking good Ewan.
One thing - I'm looking at doing something similar but ruled out the Quads because I thought they were rear ported. If they are (and Superfi think so) then you might have some issues if you are flush mounting them and putting them inside their own box in the wall. As far as I know, they will need the air to pull through the bass port at the back.
Hope I've got the wrong idea somewhere along the line though.
Jon
25-02-2008, 1:39 PM
#8 (permalink)
| | Member
Your right about the quads they are rear ported, which im hoping that having them boxed in wont make a large effect to there sound as there is space at the back of them for air to flow into them and the center is a sealed speaker no ports. The rear port on the left and rights is very small at 22-25mm.
That was a hold up for over a week was picking speakers each place was giving different views on what effect flush mounting them would have and none the other speakers that I looked at seemed to fit into the space and budget. So I took the risk and went with what i felt gave great sound.
I will post up in here what the difference is when I get a chance to hook them up.
26-02-2008, 12:51 PM
#9 (permalink)
| | Member
Cool, glad to hear its all in hand.
Would be really interested to know how they sound once you have them connected up as I'd written them off - perhaps a review might be in order! Keep the photos coming and good luck!
27-02-2008, 12:06 AM
#10 (permalink)
| | Member
Thanks: Gave 100, Got 38 | Re: my attempt at bedroom home cinema
Cracking job so far mate.... keep the pics coming! excellent! |
27-02-2008, 8:52 AM
#11 (permalink)
| | Member
Thanks: Gave 92, Got 76 | Re: my attempt at bedroom home cinema Quote: |
| - You might find you get the best results with some foam plugs in the rear ports. Or an old sock (honest).
MarkP
27-02-2008, 11:53 AM
#12 (permalink)
| | Member
Thanks for that tip markp  that was also what was told by a couple of the places I enquired about the quads, was to bung up the port and it might give an even tighter direct bass output.
just a little update,
Got a couple of packets of the remote sockets so have 6 in total, now just need to work out if can control them via my pronto.
Ordered up my hdmi splitter from ebuyer a 10m hdmi cable from ukhdmi & 50m of speaker cable going to be chased it into the walls for a 7.1 setup just in case for the future figure why not.
Have 2 new small 2 seater sofas coming today, anyones view of building a 2 teir system for them one sitting on the floor and one raised about a foot behind it?
Have attached a couple more pictures, one of the tv on the wall, one with lights on, and one showing the size of how big the bottom shelf will be due to the size of my amp, and one of my screen lowered.
Thank you all for the comments so far
27-02-2008, 12:19 PM
#13 (permalink)
| | Member
Thank you all for the comments so far[/QUOTE]
I like the led lightning. Led lightning is also very low watt compared to standard lightning and a good step forward for the home cinema industry. I only have a little in my room. What do you use for the effect? I just have mine mounted as it's behind a plasterboard (not good!!).
SONY BRAVIA 26"-PS3 60GIG-ONKYO 705-SILVER QED ANNIV EDITION-MONITOR AUDIO RADIUS 180-225-MONITOR AUDIO GLSR10-SONY VINYL PLAYER-CANON A620
PS3 HANDLE - tdtm82
27-02-2008, 12:30 PM
#14 (permalink)
| | Member
Its the 10 pack of 15mm leds from B&Q just drilled the 12mm hole and pop them in, ive got 6 behind the tv and 2 on the top shelf set pointing at an angle. I think part of the effect along the top is also caused by that ive left 2 long openings above the tv on the top shelf for air to circulate so part the light is also coming through those spaces, I will post a couple of pictures of this later showing what I mean
The remaining 2 from the 10 are for the bottom section to point to the floor, when its built.. I should say that ive also got another 20 of the same 15mm leds set into the coving in the ceiling, so the room has a blue glow at night again will post pictures later
27-02-2008, 12:58 PM
#15 (permalink)
| | Member
Thanks: Gave 5, Got 10 | Re: my attempt at bedroom home cinema
Lovin' the LEDs. Might have to nick that for by install. Good Job.
