Go Back   AVForums.com > Home Cinema Construction and Configuration > Home Cinema DIY
Latest AVForums Movie Reviews
Terminator Salvation Blu-ray ReviewNorth By Northwest (50th Anniversary Edition Blu-ray Book) Blu-ray ReviewScrooge (A Christmas Carol) Blu-ray ReviewGray Lady Down - Original Motion Picture Soundtrack CD ReviewUp Blu-ray Review
Léon Blu-ray ReviewNear Dark Blu-ray ReviewLogan's Run Blu-ray ReviewTaking of Pelham 1 2 3, The Blu-ray ReviewStar Trek Blu-ray Review
AV Distribution Again (Sorry) piers-uk Interconnects, Speaker Cables and Switches 16 12-01-2008 11:29 PM
Which distribution is the best for PS3? MegriM Linux 4 05-11-2007 4:46 PM
Help with distribution please dohboy Custom Installations and Installers 2 15-07-2007 2:57 PM
SKY HD distribution 45ure Sky HD 1 03-02-2007 8:36 PM
Has anyone got a D12 DVI distribution box? Triggaaar Sky and Sky+ 5 04-06-2006 11:40 AM
Old 04-02-2008, 6:24 PM   #1 (permalink)
Thanks: Gave 3, Got 0
Help with tv distribution
HI
I wish to sort out my viewing arrangement and sote all my equipment in one place and be able to view i the content in any one location.
I have looked at the avlynx setup and it is very good, but i would like to ad data.
I am now considering the Windows Media centre as an option and i was looking for help in the view tv in more than one location using a tv tuner card sat & freeview.
Any suggestions or help or am i looking for too much?
mjgrey is offline   Reply With Quote
Old 04-02-2008, 6:44 PM   #2 (permalink)
Daz CPFC's Avatar
Thanks: Gave 24, Got 32
Re: Help with tv distribution
Originally Posted by mjgrey View Post
HI
This can be done using windows media center using a dual output tv card so you could then in essence then link it up to two screens. I think also with an sli setup you could then make this up to four TV's. Could also go down the route of DVI splitters and the like though to get 4 displays without needing another graphics card.
Only problem is im not sure windows allows you to show a duplicate screen on multiple screens using different resoloutions on each screen.
And if you do use a media center pc and do then add a TV/SAT Tuner then i see no problems as all TV's will be linked to the same PC so will have no problems showing content.
Hope that helps a bit!
Daz CPFC is offline   Reply With Quote
Old 04-02-2008, 11:46 PM   #3 (permalink)
Thanks for the quick reply!
is it possible to distribute this to the other tv's using a network or cat5 cable?
I saw a show piece on the microsoft web site where they used extenders to distribute the content and all could work independently. but thes extenders are not available here yet
any recomends on tv cards, for sky + and freeview as well as terestrial
distribution
