Go Back   AVForums.com > Home Cinema Construction and Configuration > Home Cinema DIY
Latest AVForums Movie Reviews
Terminator Salvation Blu-ray ReviewGray Lady Down - Original Motion Picture Soundtrack CD ReviewUp Blu-ray ReviewLéon Blu-ray ReviewNear Dark Blu-ray Review
Logan's Run Blu-ray ReviewTaking of Pelham 1 2 3, The Blu-ray ReviewStar Trek Blu-ray ReviewUFC 100: Lesnar vs. Mir (2009) Blu-ray ReviewThe New York Ripper Blu-ray Review
Vinyl matt or flat matt paint for DIY screen? stuartbrown21 Projector Screens 5 06-12-2006 3:18 PM
HELP - what to paint wardrobe doors with and also screen paint - HELP MadDog Stu Projector Screens 2 28-12-2005 10:30 PM
Matt F's entry seany Digital Photography General Chat 2 02-05-2005 5:20 PM
Matt or Vinyl Silk Paint BarryTra Projectors 0 24-12-2002 8:57 PM
Paging Matt F pbirkett Hi Fi Systems and Separates 0 23-12-2002 8:45 PM
Old 03-02-2008, 9:27 PM   #1 (permalink)
Thanks: Gave 0, Got 4
ultra matt paint
just spotted this in b&q, comes in black or dark blue. has anyone tried this for walls/ceiling. its blackboard effect so should be non reflective, just wondering hoe easy it paints on.
http://www.diy.com/diy/jsp/bq/nav/na...=1202073733397
bign5 is offline   Reply With Quote
Old 05-02-2008, 8:50 AM   #2 (permalink)
MarkP80's Avatar
Thanks: Gave 92, Got 77
Re: ultra matt paint
No direct experience of this paint but I have used "feature wall" matt paint before. My main caveat would be that it is very susceptible to marks - the slightest brush against it will tend to leave a very visible scuff, so be careful where you put it. Try before you do a whole wall, and think long and hard if you have kids. And keep a spare tin for touching up!
Cheers,
MarkP
My Cinema and the Bar!
MarkP80 is offline   Reply With Quote
Old 05-02-2008, 5:16 PM   #3 (permalink)
it was the scuffing issue, that had me wondering if anyone had used this before. lucky for me there are no kids. i am planning on having the screen wall + ceiling - black, the other 3 walls blue - so long as its as dark a blue as it looks.
Old 09-02-2008, 4:14 PM   #4 (permalink)
i have also been pondering on what to do with the white painted door, that is in the middle of my ulta matt blue wall. Its got a factory paint job on it, that looks like it will be a problem to paint matt blue.
my best idea so far is to hang a black curtain on a portiere rod, which will also act as a bit of a sound damper too.
unless someone has got any other ideas?
matt, paint, ultra
